  1. 997.642.141.10 is not for the BOSE option. 997.642.143.03 is for the BOSE option.
  2. :welcome: The VIN decoder is under the top menu "Documents". The VIN does not contain any option information. Start by looking for the option code sticker on the underside of the front hood. The Option Codes Lookup is under the same Documents menu item at the top.
  3. I have a 3.6l car and am just requiring the part no's for these at the moment. Thanks 996.111.128.56 Support -- US MSRP $287.21 (each)
  4. Try 9185 or 9183 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  5. Chances are it is like the old connectors - something likely needs to slide or push to release the latch.
  6. P0455 Fuel Tank Ventilation System (Major Leak) - Below Lower Limit Potential causes: - Tank cap missing (or bad o-ring seal). - Ventilation lines detached from EVAP canister. - Ventilation line detached from tank. - Ventilation lines detached from operating vent valve. - Ventilation line detached from fuel tank vent valve. - Break in ventilation lines. Fault code 34 - Passenger compartment monitoring sensor, short circuit to B+ or faulty Potential causes" - Short circuit to voltage in wiring between the alarm system control module and the passenger compartment monitoring sensor - Passenger compartment monitoring sensor faulty
  7. Sounds like one or more connectors is not all the way plugged in - I would check again.
  8. Heated seats were always an option.
  9. Neither are anything to worry about.
  10. :welcome: Model and year of your car please? And... did you install the turbo cluster?
  11. :welcome: 996.341.053.16 wishbone
  12. 996 (normally aspirated) - Compression ratio 11.3 : 1 996TT (turbo) - Compression ratio 9.4 : 1
  13. Yes, you will need the GT3 parts with the shims. They and increased camber will improve handling but make tire wear worse.
  14. If you use the Simple Search or the Advanced Search there is a link to a popup help - it is labeled "Advanced Usage Help". The other important factor in searching is using the most unique keywords - in this case that was easy I just searched for "P1126".
  15. According to the exchange list - yes.
  16. Try 0976 or 0974 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  17. Try 4794 or 4792 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  18. Ok, thanks that makes more sense.
  19. A1 goes to chassis ground all the other wires go to the cluster.
  20. 17 digit VINs did not start until 1981 (and his car is a 1980).
  21. Sleeves from the muffler to cats is most likely then. Pretty easy to loosen and re-center the sleeves.
  22. They didn't say where the leak was? Could even be a bad header gasket...
  23. Loren
    LWFW
    As I recall the GT3RS engines are built at Porsche Motorsports - which means the tolerances are tighter and the moving parts are balanced to a tighter standard. My guess is that "stock GT3" does not get that extra balancing that could result in engine damage with a LWFW.
  24. I tried to do a search and got 45 or so pages of things like convertable tops and becker rado problems along with radio code searches. I , personally, was not able to refine the search enough to get any usful info. Ed http://www.renntech.org/forums/index.php?s...38&hl=p1126 http://www.renntech.org/forums/index.php?s...23&hl=p1126 http://www.renntech.org/forums/index.php?s...76&hl=p1126
