  1. No, I am just saying thin wall exhaust tubing (like racing pipes) sounds that way. Usually racing pipes are lighter and stronger than OEM.
  2. :welcome: No, in a MY2000 the cruise control is setup in the instrument cluster only.
  3. Please do a search it's been covered many times. Look for "windows relearn" or "windows training".
  4. Did you read the "Approved Transmission Oil and ATF (29/08)" TSB here
  5. How do you know it is above max hot? Isn't it just "full". What is the coolant temp when air temp is 37 40 C?
  6. The diagram I have came from Porsche PIWIS for a MY2009 Cayenne. So either the diagram is wrong or your car is not a MY2009. Can you PM me the VIN?
  7. The oil level sensor behavior is normal - you do not want to be at the full or over full mark. Especially if you track the car or have spirited drives. You don't talk about outside air temperature where does he live - what are the temperatures when he sees this? 5W-50 is also approved.
  8. There are two switches on the brake pedal - one for the cruise control and one for the stop lights. The stop light switch will have wire that are Black, Black/Yellow and Black/Red coming off of its connectors.
  9. Try 0155 or 0153 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  10. Try 0434 or 0432 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  11. No, you can have pending codes and some fault codes do not turn on the CEL. Faults can occur that are temporary and they correct themselves within the parameters (drive cycles) established by Porsche and the various EPA rules. Unless your car is not running right I would not worry about it. Part of both minor and major service schedules is to read out the fault codes.
  12. Do yourself a favor and stick with factory spec plugs - Beru or Bosch.
  13. Try 6464 or 6462 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST From the FAQ "I get a WAIT in the display - what do I do? You have to wait 1 hour - with the radio on and ignition switch on (or the car running)." Did you read the FAQ? I think not.
  14. Try 6464 or 6462 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST From the FAQ "I get a WAIT in the display - what do I do? You have to wait 1 hour - with the radio on and ignition switch on (or the car running)."
  15. http://www.renntech.org/forums/index.php?s...ost&p=48358
  16. Try 6464 or 6462 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  17. :welcome: Checked the fuse? (B7) If it is okay check the switch on the brake pedal.
  18. Try C3 - that is labeled inside lights.
  19. Model and year of your car please?
  20. Sorry, this is a Porsche site - please re-read the board Guidelines/Rules that you agreed to when you registered here. "Please keep your posts on topic - Porsche's and Porsche related technical discussions - period. Non-Porsche related content will be removed." Your non Porsche video has been removed.
  21. Try 3227 or 3225 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST neither of those codes worked, any other suggestions? the car is a US version, manual trans, black interior Thanks Yes, READ THE FAQ.
  22. :welcome: Looks like: A3 = black/black A2 = blue/blue A1 = brown/brown
  23. Loren
    Rev Limiter
    You can still choose the wrong downshift gear even with shift gates.
  24. Try 3227 or 3225 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
