  1. Exact model and year of the car please...
  2. (Moved to appropriate forum) P0332 - Knock sensor 2 Possible fault causes: - Loose contact or corrosion on connectors or line - Short circuit to B+/ground/between lines or open circuit in the lines - Knock sensor 2 loose or braced - Knock sensor 2 Faulty - Level Engine oil too low - Engine Faulty (Mechanical fault )
  3. Please PM me the VIN for this car and I will see if I can find the part numbers.
  4. How are you clearing it? (what tool?) Has the grounding TSB been done on this car? Also, the original seat belt buckles were replaced with a newer style (gold plated contacts).
  5. I am sending you s PM.
  6. Likely a fuel line or a junction - best not drive the car until it is repaired. Let it dry and the open the engine compartment - turn the key to "on" and then using a flashlight see if you can pinpoint the origin of the leak.
  7. Item 13?
  8. If you gave me the correct serial number that shows in the display when queried then it is likely that your radio has been repaired by a 3rd party (other than Becker). In that case I can not help you - perhaps Becker?
  9. Yes, one transmission or the other. There is no rear support for the engine without the transmision.
  10. Just take the bulb out.
  11. From the Lost Radio Code FAQ... I get a WAIT on the display - what do I do? You have to wait at least 30 minutes before trying again.
