  1. P1133 Lambda control adaptation FRAU (lower load range) - below limit value or above limit value Possible fault causes - Incorrect main filling signal from hot-film mass air flow meter - Fuel pressure too high - Injection valve faulty (dripping) - Tank vent faulty (does not close completely) or Possible fault causes - Intake system leaking (secondary air) - Incorrect main filling signal from hot-film mass air flow meter - Leak in exhaust system - Fuel pressure too low - Fuel injector faulty (stuck) - Fuel pump delivery too low P1126 Lambda control adaptation FRAU (lower load range) - below limit value or above limit value Same as above (P1133) P2177, P2187, P2179 Same as above
  2. Low fuel pressure - either a leak or a worn out fuel pump.
  3. That looks like the battery vent tube - perhaps fallen down from the battery tray. Early batteries needed a vent sinc ethey were inside (mostly) closed compartment. Later AGM batteries do not require a vent.
  4. I think you are asking about a modification no one has done. In general people tend to stick with installs from one manufacturer.
  5. Read the Lost Radio Code FAQ....
  6. Radio codes are based off serial numbers. If you gave me the correct serial number and the code I gave you does not work then it is likely that your radio has been repaired by someone other than Becker (the manufacturer). In that case I can not help you - Perhaps Becker can (for a price).
  7. I have removed the limitation for Contributing Members - enjoy.
  8. What type of attachment?
  9. If you know the original radio vendor (Becker, Alpine, Blaupunkt, etc.) they might be able to help.
