  1. Your PET is dated January 24, 2010 -- mine is dated August 1, 2021. Parts change as well as availability. The cover disc is small cost for extra insurance - IMHO.
  2. I would not do that. The correct part number for the idler pulley (for your car) is: 996 102 118 56. The cover disc keeps dirt and water out of the pulley. If the tensioner pulley does not wobble or make noise there is no need to replace it.
  3. Your car is a 6 speed? If so you can use 997 102 119 00 Idler Pulley - US MSRP $152.48 I would also replace the cover disc and bolt. 996 102 127 54 Cover Disc - US MSRP $13.07 900 378 150 01 Bolt - US MSRP $2.90
  4. Have you looked at this?
  5. 996 541 531 01 Sealing Frame - US MSRP $47.27 996 541 541 02 Decorative Frame - US MSRP $82.22 Be sure the correct adhesives are used when sealing. Porsche sells (an expensive) kit 000 043 305 35 US MSRP $169.67 Many here have had a good experience with Safelite.
  6. Yes, any Porsche diagnostic tool should work as they are all backward compatible.
  7. Consider a Donation to keep this site running please.... For Type: CR 2200, Model: BE 4362, serial# x5019019 Try 7982
  8. One per member please... For Type: CR 2200, Model: BE 4466, Serial #: 15040077 Try 4210
  9. Yes, best to just drive the car.
  10. I would clear the codes and then lock and unlock the car - re-read the codes. Those should be the clear problem. Usually one beep means there is a zone open. Based on the codes the door lock microswitch looks likely.
  11. Rennfix RENNFIX.COM Welcome to Rennfix.com Car parts, tools, and books
