  1. 999 703 265 00 Bonded rubber bush US MSRP $28.22
  2. Monterey Historic Races are always fun. When I went (6 straight years) I enjoyed the Friday practice days as the car owners had more time to talk and share.
  3. I think you are talking about the Tiptronic Gear oil cooler oil pressure line for gearbox oil cooling. (always best if you tell us what the problem is or what you are trying to fix)
  4. 997 561 956 00 Locking mechanism (right) US MSRP $56.07 997 561 955 00 Locking mechanism (left) US MSRP $67.70
  5. From the Lost Radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  6. Do you have Durametric? It should be able to reset the locking control unit.
  7. It would be best to use a Posche specific scanner like Durametric or PIWIS before jumping to expensive conclusions. I don't think I have ever seen a Gateway fail that was not damaged by accident or water intrusion.
  8. I would clear all the codes and then drive the car and see what comes back. What scan tool are you using?
  9. Have you tried retraining the window? Press and hold the down button - hold it for at least 10 seconds after the window is all the way down. Then press and hold the up button - hold it for at least 10 seconds after the window is all the way up. If the window does auto up and down after that you are done -- if not, then is likely a problem with the window regulator or adjustment.
  10. A single beep means you have a zone open. You will need PIWIS or Durametric to tell you exactly which zone is open.
