  1. DO NOT START A NEW TOPIC FOR A LOST RADIO CODE. DO NOT EMAIL ADMINS. Please read the Lost Radio Code FAQ FIRST before posting - then post in the one thread. This topic is closed.
  2. You are likely on the right path. Measure the fuel flow - one or both fuel pumps is likely bad.
  3. Probably not. You can however listen closely near the front tire on each side to see if both fans are not coming on or just one. If only one is not coming on high then it is likely that the large resistor inside the wheel well has failed. There is a DIY for that here:
  4. Looks like your PDK control is messed up. Sometimes re-programming will fix these issues. If not, it should pinpoint you to another transmission fault.
  5. Looks like a 91-1660... is a 1976 Carrera Coupe. With those old (pre-17 digit) VINs there is very little information available to lookup.
  6. Since the faults are all steering related - is there any chance that you accidentally disconnected or broke the steering angle sensor. I do not know if that tester can reset the steering angle sensor. Both Durametric and PIWIS can.
  7. The code can only be entered using a Porsche PIWIS tester.
  8. From the Lost Radio Code FAQ... "CDR-23 (or later): These radios do not have a security code - that is, not that the user enters. These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
  9. Model BE2582 is PCM. From the Lost Radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  10. That is not a number I recognize - is this a PCM?
  11. From the Lost Radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  12. The last two numbers are important. Try 8734
