  1. Those may or may not have the proper part numbers as they are old printouts. (The two I looked at were July of 2017). We (RennTech.org) have access to the same up-to-date parts list the dealers/OPC have.
  2. The number one cause of strange electrical issues is a weak battery or poor grounds. The is a service bulletin for bad cables from the battery to the main power distribution.
  3. Exact mode and year of the car please. Does the car have PASM? How old is the battery and has it been load tested?
  4. Sorry, I wasn't sure it would work on such an old radio.
  5. That is a very old radio, so I hope this works for you. Try 7023
  6. I doubt you can change the speed without hacking the code. Many issues can be fixed by re-programming the control module.
  7. There is a combination of plastic clips (which may break on removal) and double-sided tape. Use a heat gun to warm (just warm not hot) the panel then lift with plastic trim tools.
  8. For most normal brake fluid changes or flushes you do not need to purge the ABS system.
  9. So, before you spend a good deal of money may I ask is this a normal brake bleed/flush or did you replace ABS parts?
  10. Not in the US. You have to record the mileage of the old cluster and provide that information when you sell the car.
  11. Did they try re-programming the DME? I have seen that re-programming can cure a "mixed-up" DME. What are the current fault codes?
  12. Look for cracks or damage. If you find one try and glue it up - once it has dried out. If not, then may need to buy a new one.
  13. Please provide exact model and year of the car - thanks.
