  1. You to disconnect the battery before removing the electrical connectors on the seats - or you will get an airbag light. You will need Durametric, a Porsche PST2 or Porsche PIWIS to clear the airbag code.
  2. P0071 Fault entry in specified control module P0074 Fault entry in specified control module Possible fault causes - Control module is incorrectly coded - Periphery connected to specified control module is incorrect - Control module faulty (in most cases the cause is not the control module but incorrect coding!) P0491 Secondary-air system P0492 Secondary-air system Possible fault causes - Secondary air pump relay mechanically faulty (jams) - Power supply for secondary air pump faulty - Air duct cross section narrowed (pinched / blocked) - Electric switch-over valve does not function - Pneumatic switch-over valve does not function - Leak in vacuum system - Secondary air pump electrically or mechanically faulty Take it back and have them correct the faults.
  3. No mechanical override that I can see. There is an electric motor on each rear wheel for the handbrake (triggered by the switch). Are you having a problem?
  4. Sorry no, it is copyrighted material.
  5. The manual that you are quoting above has not had the 99 supplemental updates it needs to bring up-to-date with corrections and additions. That is why we suggest that folks do not use it. The 2003 revision says 52 ftlb. for GT3 oil pan and 44 ftlb. for the oil tank. (click to enlarge)
  6. Exact model and year of your car please?
  7. This is a 3 year old post that you responded to? There is indeed a fuel filter on MY02 and later 996 series cars. The fuel filter is in the gas tank and in normal operating (barring contamination) it does not need changing. But it can be changed if needed - but that will also require a re-calibration.
  8. Check with your dealer/OPC as there are a couple of TSBs for rattling noises - which may be related to your noise. Also on a car this old you should likely get the coil packs (for the spark plugs) upgraded to the latest version (to prevent power loss and misfires)/
  9. P2102 Throttle valve adjusting unit – position deviation/control range Possible fault causes: - Throttle valve adjusting unit faulty
  10. Not easy to test out of the car. It might be better to get access to Durametric, a Porsche PST2, or Porsche PIWIS tester - one of those may point to where the problem is. You did check all the fuses? Yes?
  11. Stoddard Porsche in Ohio specializes in older Porsches - so I would try them first. Also try Sunset (Oregon) or Suncoast (Florida) - a dealer may have to order them from Germany.
  12. What the DIY video here and decide for yourself...
  13. (click to enlarge)
  14. Do you see it here? This is the throttle linkages for those years.
  15. This one (item 26)? If so, then it is: 999 084 019 02 M8 hexnut -- US MSRP $5.67
  16. Please read the Lost Radio Code FAQ -- then submit your serial number here.
  17. There are some other tests you can run with Durametric, a PST2, PIWIS tester to further diagnose the problem area.
  18. The horn is still sold under several brand names - Griots and WOLO for two, Just make sure you get the street legal version.
  19. Model and year of your car please? Also, was this the Porsche kit or after market?
