  1. For sure with a Porsche PIWIS tester - perhaps with Durametric, and other scanners may be hit or miss.
  2. From the Lost Radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  3. Did you check the crankshaft position sensor? If it does see the engine running then it cut off the fuel supply.
  4. This is your third request - please consider a donation to this site for it's continued operation. Try 1062
  5. Sorry but that is normal. My 2017 GTS is the same way. There is a rumor that you change a setting with a PIWIS tester to have them on all the time but I have not tried that yet. Most dealers will not do that since that is not factory default.
  6. I am not sure what codes Durametric is pulling but those are not listed in the 991 Diagnostic manuals. Perhaps Durametric can translated them to Porsche codes.
  7. Looks like 955 110 743 10. US MSRP $51.86
  8. What's next? another Cayenne? Macan? Taycan?
  9. Not likely as it looks to be glued on at the factory.
  10. Folks we need to know the fault code numbers to look them up...
  11. That piece attaches to the radiator frame and sits in the bumper opening.
  12. You need the air guide (item 9) -- 987 575 323 00
  13. There is a wiring diagram in the (no longer published) service manual. The MY98 Boxster wiring diagram is at least 22 pages long - and is copyrighted material. Perhaps a more descriptive question of which parts you are having trouble with.
