  1. P1990 covers a whole range of similar issues Positive engine torque intervention not possible Engine torque intervention not possible SPI error Software monitoring, reset was triggered by operating system monitoring A Software monitoring, implausible calculation of engine rpm control intervention Software monitoring, calculation of Eshift position implausible Software monitoring B of signal processing unit Possible fault causes - Fault in CAN bus - DME control unit detects engine fault - PDK control unit faulty I suggest clearing the code and seeing if it comes back.
  2. And this is the Lost Radio Code thread -- you need to post in the appropriate forum please.
  3. Which item please... (click to enlarge)
  4. Please read the Lost Radio Code FAQ.... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  5. I agree with Richard - it is not (unfortunately) uncommon for this control module to get lost and need to be re-programmed.
  6. No, you ( and Loren ) are correct, I was thinking of the M96/97 layout. Yes, on the 997-2 the sump mounted oil level sender also sends oil temperature.
  7. 955 613 713 100 1C Lumbar adjustment (satin black) -- US MSRP $11.76
  8. If it is not in this diagram then it is not sold separately. If it is in this diagram then please tell me the item number. (click to enlarge)
  9. According to your VIN it is a 1975 body. Your engine serial number should start with 675xxxx.
  10. For your 2005 Cayenne... Large fan -- 955 624 135 00 Small fan -- 955 624 134 01 (this is an updated part that should directly replace the old one)
  11. PM me your VIN and I will look up your exact fit part.
  12. Try 8670 No luck with 8670 Did you get your serial number using the procedure in the Lost Radio Code FAQ? Yes, just went out and rechecked. I left off one number it says serial# X5032591. I left off the 1. When I go through the FAQ process it says 4462 then 48/98 then X5032591 then CDP2081. For the correct serial number try 0253
  13. Try 8670 No luck with 8670 Did you get your serial number using the procedure in the Lost Radio Code FAQ?
  14. Try 0781 I only have 1 to 6 buttons on it.... Sorry, you did not read the Lost Radio Code FAQ -- we do not have information for that radio (CR-1)
