  1. Model of your radio? (what it says on the front panel)
  2. The system will not bleed the ABS without turning on bleed mode using Durametric or a Porsche PIWIS tool. If you have not opened the system (introduced air) then you should be able to bleed the brakes normally bypassing the ABS/PSM system.
  3. Since you have access to a PIWIS did you check the top for faults?
  4. What make and model radio is this this? Did you read the Lost Radio Code - FAQ?
  5. I would think the instructions would come with the new part. Did you ask your Porsche OPC about that?
  6. Please READ the Lost Radio Code - FAQ
  7. I think you are looking for 996 201 265 01 Fuel line.
  8. If you apply power to the cd changer (assuming it works well enough for that) then you should be able to eject the cartridge. Black wire should be +12 volts Chassis is ground.
  9. "Question; Can the Durametic re-set/re-calibrate the top?" Yes, Durametric can re-calibrate the cab top. "Also can the Durametic set the key "fob" to open the hood "trunk" and allow the horn to alert on fob locking." No, Durametric can not program functions that are not available in the 996
  10. The usual test when a repair or upgrade has set off faults is to note them - then erase them and see if they come back.
