  1. Any fault codes? I think the cluster should be reporting faults.
  2. OPC = Official Porsche Center In the US that would be your Porsche dealer.
  3. From the Lost Radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  4. Not unless you remove the radio and the sticker matches (stickers do not always match as they are not changed after a repair). You will need radio keys to remove the radio - usually about $5 on ebay.
  5. What they call the "cap" is actually the lens housing. Do you want the color for clear (RoW) or amber (US)?
  6. As I recall it will be either under Radio or DME.
  7. That is correct - the muffler would melt it.
  8. Only MY2002 and newer have the illuminated housing. The whole illuminated housing is: 996 652 102 10 and has a US MSRP og $11.15.
  9. Try 4734 Please consider a donation to this site - that has helped you with radio codes multiple times.
  10. 996.2 is MY2002 and newer 996 - they use Aerokit II. A MY2001 996 is 996.1 and uses Aerokit Cup. I do not see that part or part number on either kit.
  11. 0W-40 should be fine.
