  1. Please read the Lost Radio Code FAQ "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  2. I would bundle and cover the electrical connectors so they can not touch chassis ground.
  3. 1. Switch off ignition and remove ignition key. 2. Use a plastic spatula to carefully unclip the covering frame, starting from the bottom left and right. 3. Unscrew the four fastening screws. 4. Carefully pull out the PCM unit. 5. Press lock on antenna connectors 1, 2, 3, 4 and pull off antenna line. 6. Release central connector for PCM 5 , fold up release (arrow) and remove connector from PCM. 7. If the PCM unit has to be replaced and a telephone control unit is installed:
  4. It would likely need to be re-programmed for LHD options (not in alarm section).
  5. :welcome: The alarm module, DME, and transceiver are all programmed together - so theoretically that could work. If the car is originally from Germany then the cats are likely a different spec - you will need to check local laws to see if they are approved for use in your country or not.
  6. Your duplicate post was deleted per board rules. Back to the topic please...
  7. Starting in MY2007 wiring diagrams are only available in PIWIS. There is no easy way (that I know of) to print them from PIWIS. Seems like the simplest solution would be to get a valet key.
  8. I am looking it up in Porsche's database - and it says "not a valid VIN". Send them a message and ask for a (good) photo of the VIN.
  9. When I tried to check it - it came up as "not a valid VIN". Please have them double (or triple) check the VIN.
  10. Panamera steel brakes: Brake disc wear dimension, front 34 mm Brake disc wear dimension, rear 26 mm Pad thickness, front wear limit 2 mm Pad thickness rear wear limit 2 mm
  11. I answered your PM(s).
  12. Really? I got 4 pages of results for P0410. Try searching the forum (not the topic) for "P0410"
