  1. I need the radio serial number (numbers). See the Lost Radio Code FAQ
  2. Try 4561
  3. Try 9875
  4. Try 0703
  5. Sounds like you have one or more locking zones (doors, gas door, rear hatch, etc.) that are not latching. You will likely need a PIWIS tester or Durametric to find the fault code(s) to easily determine the problem.
  6. Try 4703
  7. Likely a TT standard part. Not all RoW models had the manual adjustment. The US/Canada cars did not have it either.
  8. 2003 would be leds. Palo Alto Speedometer can repair both. The clock shaft plastic piece can be replaced and should work as long as the adjustment mechanism is not broken.
  9. Maintenance schedules are Porsche copyrighted materials - you need to get them from Porsche or the Porsche website. Copyrighted Porsche materials are not allowed here. Sorry 😞
  10. Then you also need to check for fault codes in the DME. You will need a PIWIS tester or Durametric to do that. Report any fault codes back here please.
  11. If it is a low speed only issue then yes the ballast (on that side) can likely be the problem.
  12. Fault 5525 Torque transmission from the DME disturbed at times Effect: - The PSM function is switched off - The ABS function is switched off - The ASR function is switched off Note! The fault is sent from the DME control module to the PSM control module via the CAN bus. The PSM system is not faulty! Possible cause of fault: - Fault in DME
  13. DId you perform a throttle adaption after replacing the throttle body? Perform adaptation: 1. Switch on the ignition. 2. Wait one minute. Do not press the accelerator. 3. Switch off the ignition for at least 10 seconds. 4. Read out the fault memory.
  14. Sorry, I would have to sit down and compare both steering wheel wiring. Porsche does not change part numbers and put year limits on them unless they have to.
  15. The correct part number for your MY2009 car is: 997 347 803 21 plus the color designator.
  16. P1503 Throttle Jacking Unit, Position Error – Signal Implausible Possible causes: – Short circuit in wiring harness – Sluggish throttle (throttle butterfly and ports dirty)
  17. Try 9485
  18. That part number (997.347.803.85) is for MY2011 and newer 997.2. What year is your car?
  19. Very possibly yes. His problem may have been the power connector in his car or even a pinched wire.
  20. Oddly sometimes an intermittent brake light switch (on the pedal) can cause this. Other things to look at are the speed sensors on each wheel.
