  1. For your radio try 0572 We do VIN lookups for our Contributing Members (see the Donate button at the top right of any page). Since this is service we are charged for we ONLY do it for Contributing Members.
  2. If it is only the lock mechanisms then it is likely the central locking/alarm control under the drivers seat. Any chance it got wet? If so, you may have a lot of work ahead of you.
  3. Please use the procedure in the Lost Radio Code FAQ to get your proper serial number - then re-post here.
  4. And it has been covered here many times over....
  5. Po Please read the Lost Radio Code FAQ for a list radios we can decode. It says that trafficpro radios can have their unlock codes decoded. Did I miss something? Thanks. Porsche TrafficPro only and then I would need the number of preset buttons.
  6. Please read the Lost Radio Code FAQ for a list radios we can decode.
  7. Is this a real PST2 or a clone? Is the card the Bosch card? If so, what is the part number on the card?
  8. Did you use method in the Lost Radio Code FAQ to get your serial number? If not, please do so and re-post here.
  9. Try 0109 If you read the Lost Radio Code FAQ you would already know the answer to that...
  10. If you can flip the switch back and forth and the result changes then you need a new headlight switch. If not, then you could have a broken connector/damaged connector pins or connector wires pushed out of the socket in the inner fender. Both have been cover here many times before... so please give our search a try once you determine the headlight switch condition.
  11. Not the first time I have misread a post... :oops:
  12. Please read and follow the instructions in the Lost Radio Code FAQ. This topic is now closed.
  13. http://www.renntech.org/forums/topic/42624-an-extension-required-to-process-this-request-is-missing/
