  1. You can buy those spring clamps at any good auto parts store. Just make sure you buy the stainless steel type. http://www.renntech.org/forums/tutorials/article/69-3rd-radiator-install-instructions/
  2. For the shifter Porsche list 100 TU or about 1 hour. If you have PCM add another 20 minutes. Cable replacement is about 240 TU so about 4 hours. Realize these book times are Porsche times based on a worst case tech (new never done it before). An experienced tech will often beat those times by as much as 50%.
  3. I have had the B&M shifter for 15 years now - still works like the day I bought it.
  4. You do not have a bad sensor - that sensor is telling you what the problem is. P1126 356 Oxygen Sensing Adaptation, Lower Load Range, Bank 1 – Above Limit Possible causes: – Incorrect signal from MAF sensor – Intake air system leaking – Fuel pressure too low – Volume supply of fuel pump too low – Fuel injectors fouled If you only have this fault not the bank 2 fault (P1133) then I would look for an air leak on bank 1.
  5. :welcome: P2177 Oxygen Sensing Adaptation, Lower Load Range, Bank 1 (FRAU1) – Above Limit Possible fault cause - Intake air system leaking - Leaking exhaust system (draws fresh air) - Incorrect main charge signal from MAF sensor - Fuel pressure too low - Fuel injector(s) mechanically faulty (sticks) - Volume supply of fuel pump too low P2179 Oxygen Sensing Adaptation, Lower Load Range, Bank 2 (FRAU2) - Above Limit Possible fault cause - Intake air system leaking - Leaking exhaust system (draws fresh air) - Incorrect main charge signal from MAF sensor - Fuel pressure too low - Fuel injector(s) mechanically faulty (sticks) - Volume supply of fuel pump too low The 300 series are misfires on cylinder 1,3, 4, and 5. If you are sure you do not have an intake leak then the fuel pump(s) delivery should be checked, If you do a search here you will see that a number of folks have had fuel pumps go bad.
  6. Check the Sport Exhaust Installation TSB here: http://www.renntech.org/forums/index.php?app=downloads&module=display&section=download&do=confirm_download&id=736
  7. http://www.renntech.org/forums/index.php?app=downloads&module=display&section=download&do=confirm_download&id=357
  8. 997 426 011 02 is part number that Porsche says to use for replacement. In the earlier shifter housing I think sometime the magnets fell out and jammed the shifter.
  9. Nope never been a filter cover on the 9x6 series. That is just the way it is.
  10. (click to enlarge)
  11. According to the parts list - yes. (click to enlarge)
  12. The most recent Porsche parts list shows 000 043 204 19 which is Mobilube PTX 75W 90 (for non-PDK cars).
