  1. :welcome: The O2 sensor would be the last thing you would change. If it was the O2 sensor then all of the cylinders on that bank would also have faults. Cayenne's have a history of troublesome ignition coils. Porsche has updated them several times. Do the tests for cracks and resistance and if more than one is suspect replace them all with the latest version.
  2. Is this a real Durametric or an eBay knockoff. I have Durametric and it worked last time I used it.
  3. 2nd time for the same radio code. Perhaps you should write this down and put it in a safe place? http://www.renntech.org/forums/topic/14539-lost-radio-code-post-your-request-here/?p=262473
  4. Well, yes and no. The PCM would be the brains of the MOST system so re-configuring would get rid of errors but I think that is about all you could do without PCM or a CDR.
  5. You would need a Porsche diagnostic to re-program the MOST (fiber optic) system - for both adding or removing devices on the network.
  6. Welcome... sorry, but do you have a question?
  7. If you followed the procedure in the Lost Radio Code FAQ then Try 9271
  8. That is not a valid radio model - is this in a Porsche? If so, what year and model please? Thank you for your reply and time! This is a Porsche/Becker Mini Disc CD changer system. It is a 911/966 2001 European model. Regards, Terje The CD Changer does not need a serial number to operate. Please READ and follow the procedure in the Lost Radio code FAQ for your exact radio model.
  9. That is not a valid radio model - is this in a Porsche? If so, what year and model please?
  10. The seat heaters fuse is on the Current Distributor panel (behind the glove box under the dash)
  11. Please READ and follow the instructions to display your serial number in the Lost Radio Code FAQ. Then post your ONE serial number here.
  12. Every cluster needs to be programmed to the car. You will need a PST2 or PIWIS to do this. OBC will need to be turned on in the cluster as well as model type settings, etc.
  13. :welcome: 1. You need a new battery. 2. check for corroded (rusty) grounds in the tail lights. Fairly common on Cayennes'.
  14. Radio model please? (CDR-220, CDR-22, etc) I dont know the model sorry, it is old 1999 boxter becker 1 type 4367 That would be a CR-22 Try 0693
  15. Radio model please? (CDR-220, CDR-22, etc)
  16. Have you added or removed anything from the MOST (fiber optic) network recently? If so, then you may need to re-code the system to identify all of the units on the MOST bus. Does your car have the Harman amplifier? If so, have you checked it's fuse (D9). Or your may just have a faulty CDR-23. There are a number of MOST diagnostic test that Porsche diagnostic tools (PST2, PIWIS, PIWIS 2) can run but I doubt Durametric can. Your best (least expensive) solution may be to find a shop with a Porsche tool and run the full MOST diagnostics to narrow down the problem.
