  1. I've had the XPEL on my Macan GTS for over six years and it is holding up real well. I did full hood, door handle (finger grip area), as well as fender surrounds and back bumper .cargo lip. No yellowing that I can tell and the only place it came up a little is on the front bumper where someone"tapped" me. The bumper is fine but the XPEL came up a little from the impact. I do not have any experience with the Hexis.
  2. Sorry, I can't help you with a Mercedes Becker radio.
  3. I do not know how the Kessy or locking system will respond to that - it may trigger a fault.
  4. You should be able to do that but you will need European chassis IPAS codes.
  5. If you get two beeps when locking then you have multiple zones faulting . If you get one beep when locking then you have one zone open/faulting. You need a Porsche specific scanner (like Durametric) to see what zone or zones are triggering or if you have a bad control module.
  6. How old is your battery - if it is 4 or more years old replace it. A weak battery causes all kinds if electrical anomalies. Since you had the door locks apart - did you inspect the mechanical levers for wear or cracks? - they can wear out and the car is 22 years old.
  7. There are three pressure sensors on the compressor (charge air cooler). items 20 and 22.
  8. 1. Likely correct that you need a new window regulator. Best done by a good shop (like Real Mean Garage {RMG) RMG ENTERPRISES 960 W. El Camino Real (in back alley) Sunnyvale, CA 94087 (408) 738-2060 2. They can likely fix your horn issue as it is quite common. Likely new (rubber) horn bushings.
