  1. :welcome: Search is your friend here... http://www.renntech.org/forums/topic/2881-cayenne-alignment-specs-needed-please/?p=13523
  2. You can try but the PST2 stopped development in early 2004 - so many of the Cayenne (and newer car's) features were not included in it.
  3. I just updated TapaTalk with their latest.... still broken for me. I'll try and re-submit another bug report.
  4. Please READ and follow the procedures in the Lost Radio Code FAQ We will answer post in that one thread ONLY. This topic is now closed.
  5. Please READ the Lost Radio code FAQ "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  6. The last update to PST2 was 2004 when it was replaced by PIWIS. It will have limited tests for Cayenne. PIWIS will have more diagnostic tests for 2004 and newer cars than PST2.
  7. For 6 preset Traffic pro try 61532
  8. If the car idles well and the problem only occurs at higher RPM - then I would suspect a dirty or bad MAF sensor.
  9. Fault codes 4, 5, 20, 21, 36 -- Ignition circuit, driver Possible cause of fault: - Short circuit to B+/grouncl or open circuit in the wiring between the driver's airbag unit and the airbag triggering unit - Driver's airbag unit faulty - Triggering unit for airbag faulty
  10. Is this in Rootwood finish? (That is what the VIN shows). If so, the plain hinged door is 955.552.167.00.4X2 -- US MSRP $233.29
  11. it would be very helpful if you would tell us the exact model and year of your car.
  12. Yes, it is the same internal filter (996.107.225.53).
