  1. Per the board Guidelines/Rules -- Please do not double post your requests. (click to enlarge)
  2. For a 6 preset TrafficPro try 12341
  3. Okay - so the headlight works you proved that by swapping with the opposite site. You changed out the wiring harness - so that should be good. What you have not done is re-programmed the computer module that turns each of those lights on - individually. Unless there is another break the wiring then it is likely a control module issue.
  4. :welcome: There is a front end electrical control module that controls all of the lights. You may need to get it re-programmed. It is not unusual for these control modules to lose some or all of their memory/programming during a battery change or other electrical anomalies. In most cases a simple reprogramming using a Porsche diagnostic tool (PIWIS) will correct the problem(s).
  5. I do not know what country you posted from but here in the US the MPG rating come from the government (EPA). So I am sure they will post them when they get the numbers from the EPA.
  6. The Boxster S brakes are the same as the 996 (two wheel drive) cars.
  7. Sorry, you can get those faults by hitting the lock button before the door is closed or before the door is closed completely and the window is up. As I said before I think you should clear all the codes and then re-test.
  8. Try 6491 Just tried, no luck... Did you follow the procedure in the Lost Radio FAQ to get your correct serial number?
  9. http://www.renntech.org/forums/links/category/7-used-porsche-parts/
  10. Next step - clear all the codes - then lock and unlock the car a couple of times. Then recheck the fault codes and tell us which one(s) remain.
  11. Yes, they will stay in the alarm control module until cleared. Whether Durametric is working or not two beeps is always an alarm system fault. One beep is a just an open zone.
  12. If you have two beeps then there IS a fault. Sorry, but you will likely need a Porsche diagnostic tool to see it since Durametric does not.
  13. If you get a double beep then you have an alarm zone fault. Durametric, Porsche PST2, or PIWIS can tell you exactly where the fault is. I highly suggest you use one of those to further diagnose - otherwise you are just guessing and that can get expensive.
  14. What you see is what Porsche offers for replacement parts. If you give me an item number I can look it up for you and give you an approximate price. If the part is not shown then you must buy the assembly instead or find the part at a salvage yard.
