  1. Anything in the wiring diagrams labeled "TERM 15" is switched power. FYI... TERM 30 is unswitched power. TERM 31 is ground.
  2. Yes and no... Yes if you do not have a proper device to hold it on the bench and No if you do.
  3. If it worked before the steering wheel change and now it does not then that is likely a good place to start.
  4. P1749 Version coding - signal implausible Possible causes: - Open circuit - Wiring - Short circuit to ground - Tiptronic control module
  5. "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  6. You obviously did not read the Lost Radio Code FAQ...
  7. You obviously did not read the Lost Radio Code FAQ... "CDR-23 (or later): These radios do not have a security code - that is, not that the user enters. These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
  8. Your duplicate post on the same topic has been removed. Please follow the Guideline/Rules you agreed to when you registered here. "Please post your messages in one forum only. Crossposting, double posting, triple posting, etc. are all a waste of time and valuable resources. If you post the same message in multiple times or in multiple forums, we will delete the ones we feel are inappropriate."
  9. I would soak them in PB blaster overnight then use a rubber mallet to try and break them loose. Last resort cut them off.
  10. Did you look at the RoW DIY here. Even thought you are not going to the RoW struts and springs the procedure is very good.
  11. One per customer - please pick one.
  12. This likely will not work but... If it is a 4 digit code try 0912 If it is a 5 digit code then try 71911 If those do not work - then sorry I can not help you.
