  1. Only to the extent that both signals go to the instrument cluster. Both are just warnings spoiler extended light or ABS activated light. I would treat as separate issues.
  2. Sometimes you can get an ABS error from wheel slip - either from wet pavement or loose gravel. In those cases it usually clears itself. Also, if your battery is 4 years old or older it should likely be replaced - a weak battery can cause all kinds if anomalies in these cars.
  3. No, the only place you can get a PCM codes is from a dealer/OPC.
  4. From the Lost Radio Code FAQ... "These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM codes is from a dealer/OPC."
  5. These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM codes is from a dealer/OPC.
  6. You will need a PIWIS tester to copy the program/codes from your old KESSY/PAS to your new one.
  7. You can carefully pull the cluster and reseat all of the cables making sure they are all locked in place.
  8. Looks like somebody's hack for Garmin or some other NAV.
  9. This the correct place to post but I need your radio serial number. Did you rear the Lost Radio Code FAQ?
  10. Hope you are sitting down... 955 555 011 02 6K1 roof trim Sand beige US MSRP $2,439.53
  11. 996 653 101 08 Control Panel -- no price -- order by request. (original) 996 653 101 HX EFR Control panel -- US MSRP $1,240.37 If you get one at a salvage yard make sure it is from a 2001 or newer 986 (or 996).
