  1. Youd did not read the Lost Radio Code FAQ... did you? "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  2. Try 7216
  3. Try 0760
  4. Try 8208
  5. If they are Porsche wheels - yes.
  6. Try 4750
  7. Try 8215
  8. Try 0243
  9. Try 5018
  10. Are you sure it is starving and not flooded? A leaking cold start valve will cause starting issues. Try starting with the accelerator pedal to floor...
  11. Did you open it and look for signs of water corrosion?
  12. Is the fault 60 the only alarm fault you get? Do you get two beeps when locking (or unlocking)? Any chance water has gotten into the car at sometime gotten the alarm control module wet? (it is under the driver's seat on LHD USA/Canada cars)
  13. Try 2387
  14. Try 8982
  15. Try 3295
  16. Try 8594
  17. Try 7636
  18. Try 9521
  19. Try 9831
  20. Try 8715
  21. Try 1098
  22. Try 8349
  23. Try 9079
  24. Try 2726
  25. Try 8686
