  1. Pretty sure I have provided this before... 996 series - Tightening torques for front axle
  2. http://www.renntech.org/forums/topic/1512-sun-visor-mirror-return-springs/
  3. Step 1 - Read the Lost Radio Code FAQ Try 2161
  4. As far as I know only by looking up the VIN and factory options.
  5. I have removed your duplicate posts - please post ONLY one time. Try 5410
  6. You need to read the Lost Radio Code FAQ - and then follow the instructions...
  7. 1. Remove hose from secondary air pump. Then separate the electric connector on the secondary air pump. Fastening screws for secondary air pump Hose and electric connector on secondary air pump 2. Unscrew the 3 fastening screws on the secondary air pump. 3. Remove pump from support. Installation is the revere - 7.5 ftlb. for the three screws. Removing bracket for secondary air pump Note: On the right secondary air pump also unclip the cooling water hose and vacuum hose. 1. Undo the three fastening screws for the bracket and remove the bracket
  8. You obviously did not read the Lost Radio Code FAQ first... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  9. Fault code 60 - Central locking limit position 'Locked' not reached Possible cause of fault - Central locking switch faulty - Short circuit to ground/open circuit in wiring between the alarm system control module, central locking switch or door locks - Driver's/passenger's door lock faulty - Control module faulty It sounds like the mechanical lock is not actually locking - just making noise. This fault happens when the lock latch mechanism breaks - unfortunately fairly common. Try the Central Locking dash switch - if still fails then it is likely the mechanical latch in the door.
  10. Exact model and year of your car please...
  11. I have removed your duplicate posts - please post ONLY one time. Try 0747
