  1. For a 3.4 liter engine the correct spark plug is the Bosch 7413 (4-prong). (14FGR 6KQU)
  2. Fault codes - fault codes - fault codes... everything is a guess without fault codes. Please provide any and all fault codes.
  3. What model radio please? What does it say on the front panel?
  4. Please READ the Lost Radio Code FAQ (as requested).
  5. Removal 1.Door trim panel - Removing and installing door trim panel 2. Return spring 2 - Unclip from the door handle 5 and the door trim panel 1. 3 Sleeve - Pull off from the return spring. 4 Oval-head screw 4 (4.2 x 13) 5 Door handle 5 - Undo oval-head screws 4 and pull the door handle out the door trim panel 1. Installation is the reverse.
  6. Technically no it is not closed - there is a separate support topic for each DIY. Just click on the button...
  7. Do a search here for "B pillar" - include the quotes.
  8. Did you see the video DIY here
  9. No - that is not allowed here. All Porsche manuals are copyrighted material and no links or copies will be provided here (for obvious legal reasons). This topic is closed and locked.
  10. Unfortunately the author has removed the PDF file. You can try and PM him.
