  1. Looks like your shop needs some re-training...
  2. Sorry, the only way to code a key is with a Porsche PIWIS, PIWIS 2, or PIWIS 3.
  3. Then 996 612 070 51 is the correct cable.
  4. Is the battery (tested) good and have you checked the grounds? Always the first two when you have strange electrical issues.
  5. As I said before... it would appear that you have a mismatch of your ABS control unit and your rate of return sensor and wheel sensors. Check the part number on your ABS control module.
  6. There is only one rear fog light on US/Canada cars.
  7. There is only one rear fog light on US/Canada cars. You did read the operator's manual section about the light switch? (just checking) I would suspect the headlight switch first (other than bulb).
  8. Per your PM to me and as I stated there... I would suggest you keep looking and perhaps a newer car that fits your budget and likes.
  9. I see you did not read the Lost Radio Code - FAQ "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  10. Are you sure you have the correct ABS unit for your car? Can you tell us more about why you replaced these parts?
  11. Exact model year of your car please? Is this a US/Canada car or RoW?
  12. Why are you posting this again? You already have this another topic. Please re-read the site guidelines/rules that you agreed to when you registered here. "Please post your messages in one forum only. Crossposting, double posting, triple posting, etc. are all a waste of time and valuable resources. If you post the same message in multiple times or in multiple forums, we will delete the ones we feel are inappropriate." This topic is now closed.
