  1. C2 to C4 (due to 4 wheel drive) uses different parts so it needs to be a like model (i.e. C2 to C2S). C2 to C2S needs rotors and calipers.
  2. P1602 Terminal 30 interrupted Possible cause of fault: - Fuses B1, F6 - Wiring - Tiptronic control module Sometimes you also get this if the battery has been disconnected.
  3. I sent you a PM.
  4. Fault C141 -- PCM 2.1, communication Possible fault causes: - No power supply for PCM 2.1 - PCM 2.1 incorrectly coded - Short circuit or open circuit in the CAN display - PCM 2.1 faulty (in most cases the cause is not the PCM 2.1 but incorrect coding!) I would reset the fault and see if anything comes back.
  5. No you do not need a radio code. Radio codes were only required for cars through model year 2002.
  6. The cam sensor is going to be a pulsed signal - you will need an oscilloscope to see that.
  7. Sunset Porsche - http://www.sunsetporscheparts.com/oe-porsche/00004400083 000-044-000-83 Design Key Head (only) -- $133.09
  8. Yes. Many folks buy the nicer Design key and transfer the pill and metal blade.
  9. Search is your friend...
  10. Please do not type in ALL CAPs - on the Internet that means shouting. And I sure you don't mean to shout.
  11. The mechanical key should work the same as the remote key fob - as far as activating and deactivating the (factory) alarm.
  12. If you take the transponder pill from the old key and put it in a new key - no programming is needed.
  13. The mechanical key should work the same as the remote key fob - as far as activating and deactivating the (factory) alarm. Have you changed the key fob battery? Clean the buttons and look for debris on the circuit board inside when you change the battery - blow or carefully wipe out any debris. Your key fob/key is likely 16 years old and the buttons and pcboard buttons will eventually wear out.
  14. I do not think a wiring diagram will help you. You need to trace the wires back and eliminate the caue(s). P0349 Camshaft sensor, open circuit Possible fault causes: - Signal line open circuit - Hall sensor faulty - Rotor hall sender (sensor wheel on camshaft) faulty
  15. Yes, just click on the Donate link at the top or bottom of any page and follow the directions. Thanks!
  16. Model number on the front of the radio please?
