  1. Please read the Lost Radio Code FAQ... we do not have codes for any radios other than the ones listed in the FAQ.
  2. Yes, you likely have a seat belt fault. You will need Durametric, a Porsche PST2, or Porsche PIWIS to get the exact fault.
  3. There are still three light bulbs used in the MY2001 and newer LCD clusters.
  4. Please read the Lost Radio Code FAQ... we do not have codes for any radios other than the ones listed in the FAQ.
  5. Yes, they are the same (all the parts are 997 numbers).
  6. Many of those could the result of a weak battery. If the battery is 4 year old (or older) it should be replaced and the codes should be cleared. Then drive the car at least 5 miles and re-test.
  7. I do not see anything that jumps out at me. The car looks pretty normal for an 11 year old car.
  8. You did not read the Lost Radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/ OPC."
  9. Did you use the procedure in the Lost Radio Code FAQ to get your serial number? If not, then please do so and re-post the correct serial number.
  10. How many radios do you have? Perhaps you should consider Contributing to this site? Try 4925
  11. PM the original poster. This topic is closed.
  12. You need to read the Lost radio Code FAQ... then follow the procedure to get your serial number... THEN post it here.
  13. You did not read the Lost radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/ OPC."
