  1. Sorry, no. The only thing I did with POC was the annual Make a Wish ride alongs at Laguna Seca.
  2. That is not a Porsche radio - so this may not work. Try 9618
  3. I would also look at these in order of known failures... - ignition switch - wet/damaged immobilizer control unit (under the drivers seat) - positive lead from battery to starter/starter solenoid - crankshaft position sensor (can usually be found with a Porsche specific scan tool).
  4. From the Lost Radio Code FAQ... "CDR-23 (or later): These radios do not have a security code - that is, not that the user enters. These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
  5. From the Lost Radio Code FAQ... "CDR-23 (or later): These radios do not have a security code - that is, not that the user enters. These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
  6. If you look at my third radiator install DIY the first part deals with front bumper removal.
  7. Perhaps a pending fault since it is intermittent. Don't forget about the crankshaft position sensor.
  8. Lost Radio Codes DO NOT START A NEW TOPIC FOR A LOST RADIO CODE. DO NOT EMAIL ADMINS. Please read the Lost Radio Code FAQ FIRST before posting - then post in the one thread.
  9. Left Front sensor -- 997 612 755 01 sender wire (pad wear indicator) US MSRP $59.28 Right Front sensor -- 997 612 757 01 sender wire (pad wear indicator) US MSRP $59.13 Sensors include cable and connectors... item 7 Rear (same for both sides) -- 987 612 676 02 sender wire (pad wear indicator) US MSRP $35.64 You can get better Porsche parts pricing through Sunset Porsche (board sponsor): Factory Porsche Parts, Tequipment and Selection (Boutique) Phone: 1-888-502-5927 Email: http://www.sunsetporscheparts.com/contact-us Genuine OEM Porsche Parts | sunsetporscheparts.com | Sunset Porsche Parts WWW.SUNSETPORSCHEPARTS.COM Find genuine OEM Porsche Parts direct from sunsetporscheparts.com at unbeatable prices. Also find Porsche Drivers Selection gear and accessories. Shop Securely Now.
  10. From the Lost Radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  11. There are several brake options, different size rotors, etc., including ceramic rotors. PM me your VIN and I will lookup which fit your brakes.
  12. What scanner did you use - that is not a Porsche fault code.
  13. Of course there nothing under the seat jamming the seat movement (it does happen). Did the car ever leak and did the seat memory control module get wet?
  14. You should ask your dealer for these TSBs. I can not give you copies for copyright reasons.
