  1. It is always helpful if you give the exact model and year of the car.
  2. Try 6756 If that does not work then your radio has likely been repaired by a third party. In that case only Becker Autosound can help you... sorry.
  3. Did you use the Lost Radio Code FAQ procedure to make sure you have the correct serial number? If not, then please do so and then post the correct serial number.
  4. Radio codes are specific to each radio. You need to read the Lost Radio Code FAQ... Try 4131
  5. You need to read the Lost Radio Code FAQ - we can not support that radio.
  6. 8009 Driver's belt tensioner Possible fault causes: - Short circuit to B+/ground/between lines or open circuit in the lines - Connection with other ignition circuit - Driver's belt tensioner faulty - POSIP triggering unit faulty
  7. Porsche book time is 100 TU (or one hour). That includes vacuum bleeding the system for coolant lost.
