  1. There are many connectors on these cars and this tool has 12 barbs. And, yes I own and use one. Chances are it has the correct one for that connector - if not there are other tools, but you may have to buy them individually.
  2. You likely want the Sir Tools ST9025.
  3. For a 6 preset Traffic Pro... Try 42111
  4. Sorry, you did not read the Lost Radio Code FAQ... "Can you give me a code for my PCM?These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.Sorry, the only place you can get a PCM code is from a dealer/OPC."
  5. Sorry, you did not read the Lost Radio Code FAQ... "Can you give me a code for my PCM?These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.Sorry, the only place you can get a PCM code is from a dealer/OPC."
  6. For the fog lights check fuse A7 - it's 25A. AC is fuse E7 - it's 7.5A. If fuses blow again then you will need to find out what got melted. If that is the case, then start with the light switch itself.
  7. Ok - sorry, for Entry and Drive... When locking by one finger on the door handle (button). The emergency flasher emits two flashes and an acoustic signal will sound twice. With the two beeps, all zones should be locked and the side view mirrors should fold in. My car (2017 Macan with Entry and Drive) does this though I think I might have heard it auto lock - and I think it only beeped once when it does that.
  8. Exact model and year of your car, please?
  9. Yes, but radio components have been changed and your code could be anything now.
  10. You must have Porsche Entry & Drive. You need to state that when asking alarm questions as the manual system and Porsche Entry & Drive act differently. As will locking the door with the key only.
  11. If the code I gave does not work then it is likely that your radio has been repaired by a 3rd party (rather than Becker). You will need to contact Becker North America to get this resolved.
  12. Exact model and year of your car, please?
  13. Do a search here - oil in coolant has been covered it detail many times. The news is not likely good.
  14. Moved to the correct forum - this is a normally aspirated 996.
  15. What is the model on the front of the radio? (i.e. CDR-220, CDR-22, etc.)
  16. Correct, when your alarm is functioning properly there are no beeps.
  17. Is this car a Turbo or normally aspirated 996? You state it is a 3.4-liter car - all 996 Turbos are 3.6 liters. Two very different engines.
  18. Please do not double post. You already posted this.
  19. One beep means an alarm zone is open. Two beeps indicates there is an alarm fault. You will need Durametric or a Porsche diagnostic tester to further narrow the issue.
  20. Yes, MY02 to MY05 x50 are based on the GT2 exhaust and thought there was a part number change they should all fit.
