  1. You need to read and follow the procedure in the Lost Radio Code FAQ. This topic is now closed.
  2. You did not read the Lost Radio Code FAQ... we can only get codes for the radios listed there.
  3. You did not read the Lost Radio Code FAQ... "Can you give me a code for my PCM?These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.Sorry, the only place you can get a PCM code is from a dealer/OPC."
  4. You need to go a Porsche dealership/OPC - show proof of ownership - then ask for your IPAS codes. They will likely give you a printout. Protect that printout because with those codes someone could steal your car. Think of them as a combination to a safe.
  5. We do not support the Becker Mexico but... Try 0909
  6. You need to read the Lost Radio Code FAQ... "CDR-23 (or later):These radios do not have a security code - that is, not that the user enters.These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
  7. When re-programming a DME the only tool that will work is a Porsche PIWIS with the proper (your car AND the donor car) IPAS codes.
  8. The service manual says "210/220 EMSAF carbon mod oil" for the electronic rear diff. 1.3 liters for drain and refill.
  9. They are pretty inexpensive from the dealer - just a few dollars as I recall. Sorry, they cannot be posted here due to copyright laws.
  10. That is in the Control Unit Comfort Systems Rear. 955 618 059 01 Control Unit Rear -- US MSRP $320.72 I would certainly get a Porsche shop with a PIWIS to try and re-program the unit before replacing it. Also, make sure your battery is less than 4 years old and has been load tested.
