  1. The rotor/caliper size is in all option lists. Send me your VIN in a PM and I will look-up your car's options.
  2. Exact model and year of your car, please? Also, please follow the rules you agreed to when you registered here... Please post your messages in one forum only. Crossposting, double posting, triple posting, etc. are all a waste of time and valuable resources. If you post the same message in multiple times or in multiple forums, we will delete the ones we feel are inappropriate.
  3. I already posted your code right above your last post...
  4. READ the Lost Radio Code FAQ and then follow the procedure there.
  5. You will need a Porsche diagnostic tool to attempt a re-program of the DME. If that fails you will need a new DME and a Porsche diagnostic tool to program it.
  6. You will need a Porsche Diagnostic tool (i.e. PST2, PIWIS, or PIWIS 2, or PIWIS 3. Sorry, no other way.
  7. P1507 Throttle jacking unit, gain adjustment - signal implausible Possible fault cause: - DME control module faulty
  8. Exact model and year of your car, please?
  9. The MAF has little to do with idle speed - as a matter of fact, you could disconnect it and the car will likely idle fine. If your car is a C2 check your throttle cable - it may have come off or is broken and jammed open. Barring that occurrence then unplug your MAF and see if the end starts and idles. I have never seen a MAF cause that but it would eliminate the MAF.
  10. You did not read the Lost Radio Code FAQ... "Can you give me a code for my PCM?These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  11. Sorry, only radio codes in this thread. please post your CD Changer issue in your car's forum. Thanks.
