  1. You might want to check that your Durametric is up to date with revisions. Also, it could be a bug in the software - but the only way to tell might be using a PIWIS tester.
  2. From the Lost Radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  3. Many times control unit issues can be fixed by re- programming that module. If that does not work then a new control unit will need to be installed and programmed to your car.
  4. Pretty much the brake switch and control unit. Assuming there are no shorts to ground it is likely the issue is in the control unit. Many times control unit issues can be fixed by re- programming that module. If that does not work then a new control unit will need to be installed and programmed to your car.
  5. The first thing I think is to make sure it is the stop light or tail light or fog light.
  6. I would make sure it's not the fog light, also a bad headlight switch could also cause the issue.
  7. From the Lost Radio Code FAQ.... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  8. Yes, the required emergency release inside the trunk (red handle).
  9. #17 is the emergency cable connect.
