  1. Exact model and year of your car, please...
  2. Yes, 99 supplemental updates for the 996 service manual.
  3. 996 Mk1 use 14FGR 6KQU. From the Porsche 996 Service Manual:
  4. No - Porsche has Porsche specific codes (just like MB, BMW, and just about all car makers).
  5. According to the Porsche PET parts list your model year 2011 should be part number 997-113-026-32.
  6. Sorry, you are correct for the 2.7-liter engine: 1.6 + 0.05 mm. Most are new spark plugs are pre-gapped so you likely are just checking.
  7. Resistance does not matter unless one or more has a huge difference. What does matter: Spark Plug electrode gap: 0.7 mm + 0.1 mm Check spark plug connectors. Resistance: approx. 2 k ohms Check ignition coil(s). The resistance between terminal 1 and terminal 15 at 20°C: 0.3 - 0.7 ohms
  8. That is not your serial number please read the Lost Radio Code FAQ.
  9. Yes, you can use a plastic tool to get behind the screw head and apply pressure as you unscrew it.
  10. I think you will find a PCM 2.1 manual from any Porsche dealer for under $20.
  11. From the Lost Radio Code FAQ... "I get a WAIT on the display - what do I do?You have to wait at least 30 minutes before trying again." Then try 5430
  12. GT3 997.1 is pretty much the same as above except that dimension C is 45 mm+/-1 mm. Center on the lid left to right.
  13. Other than looking for damaged/crushes lines on the underbody - you are left with the slave and accumulator.
  14. They have different part numbers - sorry, I do not know why. You might have to compare them at a dealer.
  15. Check the wiring and connectors to the secondary air pump. If all look good then wiggle them some and see if you can make it happen. If not, you may just have a worn out secondary air pump.
  16. I've seen something as simple as worn tires cause faults like that - so start with the easy stuff. If you have Durametric (or access to a PIWIS tester) check for fault codes that may help narrow down the issue(s).
  17. N 907 798 02 Speednut for Sunvisor mounting -- US MSRP $0.72 each N 105 665 01 Self-tapping screw - 4.8 x 25 -- US MSRP $0.30 each
