  1. CDR-23 will only work on MOST equipped cars MY2002 and newer. They must be installed with PST2 or PIWIS. For CDR-220... Try 5430
  2. Make sure it is the engine mounts. Replacing them requires lifting the engine (usually an engine hoist and the proper hardware bracket to not damage the engine). Sorry, not likely at DIY in my book.
  3. Porsche stopped printing service manuals in 2006. All technical service information is in PIWIS. A PIWIS lease runs about $18,000 per year. Ask away here lots of knowledgeable folks here to help.
  4. I would replace spark plugs and coil packs. The car is 16 years old - plastic is going break. If the coils test well now they may not after being hit with water. I would not put coils like that back in a car - it's just asking for future problems.
  5. No, the CPS is just a sensor. It sends a signal back to the DME.
  6. 955.618.023.05 is correct for your car. 955.618.025.03 is also correct for your car. Always give your VIN when ordering parts from a Porsche dealer - so you can be sure of any minor build differences.
  7. Please do a search for P1128 and P1130 - they have been covered here many many times. Likewise for the window not dropping when the door handle is pulled (microswitch). Worn latching rod in the affected door(s).
  8. Sometimes there can be a binding in the pedal mechanism - check for debris, clean and lightly lubricate the bushings. Also, check the clutch power spring (item 9) for binding or wear.
