  1. Latest update (Sept 27, 2004) now includes 987 and 997. Thanks Scouser! :thumbup:
  2. I don't think you could call it common but I know of at least two other cases of faulty (leaking) oil senders.
  3. No gods here - just people helping people...
  4. (for standard 996 not C4S) Brake discs Front: 318 mm Rear: 299 mm Effective brake discs Front: 261.8 mm Rear: 247.4 mm Piston in brake caliper Front: 2 x 40 + 2 x 36 mm Rear: 2 x 30 + 2 x 28 mm Brake pad area Front: 254 cm Rear: 196 cm Total: 450 cm
  5. 955 701 105 00 G2X Support (prime coated) for ECE large plate 955 701 105 01 G2X Support (prime coated) for smaller RoW plate You will most likely have to order this from Gert (Carnewal.com) or find a US dealer that can get it.
  6. Yes, the lower shelf has a different curve in the faceplate since it sits lower in the console curve. Lower Shelf - 996 552 243 01 01C satin black or 996 552 982 01 xxx Shelf (replace xxx with appropriate leather color code) or wood or carbon fiber
  7. Leave the center console open... any open zone will cause a beep.
  8. Those specs are for 996 brakes - Here is the same info on the GT3 brakes since they are about the same as TT/GT2: Brake disc thickness, new -- front 34 mm, rear 28 mm Minimum brake disc thickness after machining* -- front 32.6 mm, rear 26.6 mm (* The brake disc must only be reworked symmetrically, i.e. from both sides evenly.) Brake disc wear limit -- front 32.0 mm, rear 26.0 mm Peak-to-valley surface roughness of the brake disc after machining, max. -- 0.006 mm Thickness tolerance of the brake discs, max. -- 0.02 mm Lateral runout of the brake disc, max. -- 0.03 mm Lateral runout of the wheel hub, max. -- 0.03 mm Lateral runout of the brake disc when installed, max. -- 0.06 mm
  9. I don't know the original thickness but the wear limits on 996 and GT3 is 0.6 mm.
  10. In the SF Bay Area (a good shop) will run you about $800 - $1000 for the install and another $180 - $200 for a four wheel balance. YMMV...
  11. 1. No, when used with the proper wheel bolts (Porsche sells a kit) they are fully approved by Porsche. 2. A slightly wider track. You may notice a very slight improvement in low speed cornering - 5 mm is not very much.
  12. For my 2 cents... I'm not sure of the quality being a problem on the PSE. What I have seen is two or three PSE's delivered in a box that looked like it was run over by a truck. I don't think the shipping packaging done by Porsche is very good. If you compare it to say the Litronics that come double boxed and foam lined. Considering the cost they (or their vendor) really should package them better for shipping. End of :soapbox:
  13. Have a look at this thread
  14. Looks like there are 5 screws on the inside of the glovebox lid and 3 more on each side to remove the inner liner. Then there are 2 screws on the inside of the lock.
  15. MY02 on C4S (cast iron brakes not PCCB) Front - Pads: 996 351 949 12 (1 set) Damping Plate: 996 351 089 00 (4 needed) Wear Sensors: 996 612 365 00 (as needed) Mounting Parts Kit (bolt, spring clip): 996 351 959 11 Rear Pads: 996 352 949 02 (1 set) Damping Plate (28 mm): 964 352 096 01 (4 needed) Damping Plate (30 mm): 964 352 096 00 (4 needed) Wear Sensors: 996 612 365 00 (as needed) Mounting Parts Kit (bolt, spring clip): 996 352 959 11
  16. Most of the oil leaks were fixed by the MY2000 builds. Some common locations (besides the RMS) are valve cover gaskets and cam sensors. You need to have a look at where the oil is dripping down at.
  17. Most oil leaks can be repaired with the engine in the car. The most common exception being the RMS (Rear Main Seal). When repairing the RMS the transmission is removed and the engine is supported in place. What year and model car?
  18. Can you post a picture? Still not sure what part you mean.
  19. To my knowledge - not without going to a racing fuel cell.
  20. Sunset Imports in Oregon has all of mine except one (supp 87) we are waiting for.
  21. For the most part yes. The coat hook slides up and off. Then you will need to take the bolt out of the seat belt slide and remove the screw in the B pillar. Then that part of the B pillar will come off. The rest comes off by pulling inward along the roof (C pillar) and the windshield (A pillar).
  22. Tom Morris has a great DIY for this. You can find it here
  23. I don't see graphite gray in the parts list so that headliner will likely be a special order - and without sunroof. To relace it you will need to remove the A, B and C pillars. There are 8 clips that hold it in place. I do not know if they can be reused or not.
  24. Okay, the link is fixed.
  25. Yes. Any of the factory rockers switches will work. Which switch do you want to use? Here is a few of the common ones Yoseif's Switch page
