  1. I paid $64.99 plus tax.
  2. I just bought a new battery from Autozone, as suggested. I tried Costco and while the prices were excellent, my Costco did not have group 48 and were all sold out of group 47. I got a group 48 from Autozone for $65. It is a "Duralast" brand but does not look the same as the one pictured. Also, mine did not come with a vent tube and there does not appear to be anywhere for a vent tube to go. Dumb question but is that bad? Since there is a vent tube attached to the original battery that leads in to the firewall area, what the heck do I do with it? Just let it hang loose? Guess who's battery died today? (mine). I got the Autozone Duralast and the guy said it didn't have a vent tube - I asked him to check again or look at another battery - Oh, he says... I guess it does have one. This is what I bought and installed today...
  3. Likely any will fit. I think they just changed the color/style.
  4. 996 555 623 00 01C Cap (Satin Black) to MY99 996 555 623 01 V01 Cap (Silver) MY00-02 996 555 623 02 V03 Cap (Silver) MY03 on
  5. Window - no, door panel - yes at least the top corner near the clip. 996 537 085 07 Left Outer Gasket 996 537 086 07 Right Outer Gasket My price list is about 1 year old and it shows a retail price of $256.76 each.
  6. That rubber trim wraps around and down under door. It is all one piece. There is a clip behind the inside door panel that fastens the top rubber piece (near the door handle). Then you can carefully pry out the bottom from the clips that hold it in place.
  7. See TSB 6/04 6690 Trailer Hitch Installation Instructions (Option 1D6) (dated 7-9-04) in the TSB section. Perhaps their PST2 is not up to date (software wise).
  8. Could be anything in the picture above. According to the OBD II Manual:
  9. Would that be this connector?
  10. For 996 Cab (to My99) - 996 555 181 13 A11 Black Leather Lining for left windscreen (top) frame
  11. A good read... The "Warped" Brake Disc and Other Myths of the Braking System
  12. Might be a good idea to look for any loose hoses as an intake leak can also cause some hunting. Also, have you had the battery disconnected recently?
  13. Is the AC on? That will raise the idle about 200-300 RPM. If not, try a bottle of fuel system cleaner (like Techron).
  14. Do you have a picture you can post?
  15. Your dealer should do this at no charge. Do you recommend upgrading to 3.0 OS and getting the new Map? For your car you likely need to check the VIN with your dealer. If your car is a true MY03 (not a MY04 build) then your current software version 2 is correct and can not be updated. Your dealer can make one phone call using your VIN to PCNA verify whether your need or can use the update.
  16. Your dealer should do this at no charge.
  17. Hmm... the noise might have been the motor trying to return the spoiler to it's down position - so it could be a motor or microswitch problem. I would remove the fuse (D8 - or fourth row down eighth from the left) and not drive over about 60 MPH until it is fixed (JMHO).
  18. None of the next gen cars (Cayenne, Carrera GT, or 997 ) show a flasher relay in the parts list. Perhaps this is now done electronically in a control module? We'll keep checking...
  19. Under the carpet behind the seats. You will need to loose some bolts to lift the panel.
  20. Have you checked the spoiler fuse? Row D Fuse 5 (that would be 4th row down 5th fuse from the left - 15A). The spoiler relay(s) are behind the rear seats next to the DME. They are relay 3 spoiler extension (1st row 3rd relay from the left) and relay 9 spoiler retraction (2nd row, 3rd relay from the left). Both are p/n 996 615 102 00.
  21. I found it! It is... 986.331.361.02. The part in the pic does not look like the one on my car. Must be a different year. 986 331 361 03 replaces 986 331 2361 02 For a MY01 you need: 986 331 361 03 Spoiler (2 per car) 999 507 774 40 Pushbutton (2 per car) 999 507 775 40 Pushbutton (2 per car)
  22. I haven't heard of folks having much luck with fixing the flexible plastic bumper covers - they are not like a fiberglass cover. Here is a diagram with the front bumper mounting pointing (highlighted in purple).
  23. You could try naval jelly to clean the rust. Then use some anti-seize on the threads and paint the heads - but they will likely rust again in a few years.
