  1. Yes and no. If you use the stock harness the brake light will work but the spoiler light will be on all the time. You will either need an Aerokit harness or rewire the pins the existing harness. See the thread here.
  2. Doug, Sorry about your problems. Just make sure they put the same version on both sides. Porsche warns about this in the installation TSB.
  3. It is on the air box and you will need a special security Torx ( a Torx with a hole in the center. There is a Boxster discussion here - similar but don't use those part numbers.
  4. Well, you might try to find an independent shop with a PST2 so they can read out any ABS or TC faults (stuck valve?). Plus they can activate the ABS and TC pumps during bleeding with a PST2.
  5. 6 speed or Tip? Does the car have Traction Control or LSD?
  6. Well, it wouldn't hurt since you don't know when it was last changed. It is one more variable to remove. Another thing to try would be to remove the battery connection for at least 5 minutes (be sure you have your radio code and radio stations written down). Disconnecting the battery will force the DME to reset and re-establish it's levels. After you re-connect the battery it should hunt at idle for a few minutes and then level out.
  7. Manual transmissions are pretty easy. Just follow the Carrera DIY here.
  8. What does the idle do? Does it hunt? (go up and down) or does it stumble and almost stall? Also, I didn't see fuel filter on your list... when was the last time the fuel filter was changed?
  9. Folks... the key here is that if your stock shifter is shifting correctly then the B&M will also - as long as you mark the cable positions (or count the threads) before the change over. I have probably done 2 or 3 dozen of these and I have never had to use the alignment tool on a car that was already shifting correctly.
  10. Ask them for the error code that the OBD II is recording. It should be Pxxxx and could be more than one code.
  11. I don't see one for 45k but here is the standard schedule for a 1995 Carrera:
  12. Porsche suggests inspection of hoses at 30,000, 60,000, 90,000, 120,000 miles but does not recommend replacement unless leaking or damaged. Here are the hose clamp locations (both pics for C2) (a C4 is slightly different):
  13. For the height check of the ready-to-drive vehicle (full tank and tools), place the vehicle on a level surface or on the measuring platform. Front axle Measure from wheel contact surface to the lower edge of the hexagon-head bolt of the tension-strut screw connection to the body. Rear axle Measure from wheel contact surface to the locating bore in the rear-axle side section (between toe and camber eccentrics).
  14. DIY pages are free to all members... Surely you mean donate to Renntech.org? :rolleyes: Rennlist is a fine forum but the technical stuff is here... :lol:
  15. Loren, would it be possible to tell from TSB what Mobil 1 weight would be recommended for "severe duty" (oil changes more frequently due to lots of city driving, more cold starts, etc.) in a warm weather climate. Failing that, is the TSB available online anywhere? Porsche's approved list does not make any recommendations for what other car makers call "severe duty". All of Porsche's approved oil are high quality severe duty oils. Only hydrocracked or synthetic oils are approved by Porsche. Temperature wise Porsche states: Above -12° F. (-25° C): all oils approved by Porsche for the vehicle type to be considered Below -12° F. (-25° C:: all oils approved by Porsche for the vehicle type to be considered which have the SAE class OW at lower temperatures. Contributing Members here can view all TSBs. If you would like to donate just click on the Donate to RennTech.org. Contributing Members also get a special forum just for Contributing Members, larger personal mail box limits, they can send attachments in personal mails and they have much higher image storing limits.
  16. What is the Pcode? Very few bad O2 sensors (IMHO) more likely an intake or emissions leak.
  17. Hehehe... Hint - how do you get a RoW car in North America?
  18. ncp oils are synthetic (or "non-conventional processing") oils. GL oils have good light running properties because of their light low-temperature viscosity as well as a high level of temperature stability. G rated oils can be used as non-seasonal oil, but do not have the same light running properties as "GL" oils.
  19. The TSB for "Porsche Approved Oils" is 8 pages long. Most of the common ones are in the list below: Mobil 1 0W-40 ncp GL (factory fill) Mobil 1 5W-40 ncp GL Mobil 1 5W-50 ncp GL Castrol Syntec 5W-50 5W-50 ncp G Castrol Syntec 5W-40 5W-40 ncp GL Mobil 1 Tri-Synthetic Formula 0W-40 ncp GL Texaco Havoline Synthetic 5W-40 ncp GL
  20. 6/00 5517 New Microswitch For Front Lid Lock (dated 12-22-00)
  21. Yes, the vent is the oval opening in your pic. The supplied tubing is larger than ours but it is not a problem as the small plastic coupler is large on one end (for the new supplied tubing) and small on the other end (for our original tubing). I did have to cut the original battery fitting off the the original tubing as it seemed glued on. The clear plastic is original and the black is supplied with the battery.
  22. You can buy them here
  23. I paid $64.99 plus tax.
