  1. Maybe a little more tire wear... but improved handling.
  2. I used a Q-tip to push the "rubberized" sticker material until it would peel off in sections. You need to be patient and work on a small section at a time. Probably about 30 minutes per visor.
  3. Uh... the Boxster has a higher percentage (60%) German parts that the Carrera (55%)? (Even though the Boxster is made in Finland and the Carrera in Germany :lol: :lol: :lol: )
  4. 1. Usually the car will run very rough and likely throw a CEL. 2. For a MY99 C2 (no egas) that is the correct part number. (Current retail price is $433.38). 3. Without excess oil from over-oiled aftermarket or other debris damaging it. Most likely 5-10 years minimum. When my car was under warranty the dealer replaced the MAF when they didn't need to. Problem was actually something else - so it can be mis-diagnosed.
  5. XKN - speaker covers in root grain maple, dark (my list says RoW only) XKS - center nozzle bracket in root grain maple, dark (my list says RoW only) ;)
  6. Just go to the "MY04/MY05 Order Guides" link near the top of the page and pick Boxster. You will get a PDF of all the standard features and options.
  7. Have a look at the DIY here it has everything you need.
  8. Depending on the manufacture date of your car you may not need the triple square. It's best to crawl under and have a look before you buy it. Try Sears first for the 17 mm allen wrench if not there try Wiha Professional Hand Tools. MAF removal
  9. Hmm... was $65 a year and half ago. When I looked it up just now in the December 2004 price list (current) it shows retail $124.09. Still high but not what you were quoted. Why don't you try Sunset Imports? They are the link at the top of the page "Porsche Parts at Dealer Cost".
  10. And the A9 and A10 fuses are 15A not 7.5A? Right? and the ground wire on the passenger side (in front trunk) has a clean good connection?
  11. Only Contributing Members can view the TSB content. If you would like to become one then just click on the Donate to RennTech.org link at the top of any page.
  12. They shouldn't be related - the backup lights are on a different circuit. For the backup lights it's pretty much the fuse and the backup switch on the transmission. Have they had the engine or transmission out recently? If so, it could be they forgot to hook the backup switch wires - it's happened to a couple folks. For the headlight issue - get your headlight removal tool from the car's tool kit and remove that headlight. Look at both the pins on the headlight for bent pins and/or corrosion. In the socket inside the car look for corrosion again and/or for a pin that has pushed back out of the socket. These are the most obvious things we've seen before - good luck!
  13. Have a look at the air filter change DIY here
  14. Chances ae they are held on the same way the 996 are - double stick tape. First mark on the door seal (the rubber part) with tape so you know where to locate the new ones. Most folks find a combination of hair dryer (to warm the surface up) and dental floss to break the seal of the tape work well. Be careful that you don't get the dryer too hot and melt something. Once they are off clean the surface with some 3M General Purpose Adhesive Cleaner and then once dry apply the new one to your marks.
  15. 1. Have a look here 2. 96 ft lb. 3. All the bulbs are listed in your Owners Manual. 4. There is a kit that has everything you need. Have a look here
  16. XMP=Leather Visors with lights and Vanity Mirror? Correct! As stated in PET: "Sun visor in leather, 2 illuminated vanity mirrors"
  17. Front parking light (up to MY '01): Shape W, Output 5 W Front parking light (Litronic, Bi-Xenon headlight as from MY '02): Shape H, Output 6 W
  18. An RMS change takes: 4 hours - if they have the parts in stock and the technican is trained. 1-2 days - if they have to order the parts. (why not wait until the parts arrive?). 2 days - 2 months - if they have to (order and) replace the engine.
  19. My first thoughts are: Bad gas (octane too low - knocking?) or a bad ignition switch...
  20. Yes, I'll send you a PM with some troublshooting...
  21. Most common cause I've heard about is corrosion or loose antenna connections. If it's AM reception, then there is a TSB that details a Suppression Kit that needs to be installed on pre Oct 1998 build cars.
  22. 996 652 101 00 Cigarette Lighter (to MY01) ($9.83 Retail as of Dec 2004) 999 650 284 40 Plug Socket ($0.40 Retail as of Dec 2004) 999 652 735 12 Connector($0.29 Retail as of Dec 2004)
  23. It is a Torx E12 socket. "E" is for External.
  24. You've got a PM...
  25. 996 424 075 01 EKS Gear Shift Knob (original) available stock only 996 424 075 02 ENK Gear Shift Knob Savanna and Silver 996 424 075 05 ENK Gear Shift Knob (MY00-02) Good Luck!
