  1. If it were my car the first thing I would do is drain the transmission oil and look for metal. Since your car is likely still under warranty - you might want to take it to the dealer for a transmission check.
  2. I'm pretty sure they won't come with it. Oops.. the TT doesn't use the plastic screws the GT3 and Carrera use, it uses U-clamps. If they don't come with it then order 999 507 751 02 U-clamps.
  3. 996 555 081 02 A18 Lining Black Leatherette - retail $383.05
  4. I drove on the boards (backed on in this pic). The bottom board is about 6 inches longer than middle board which is about 6 inches longer that the top board. So there is a stair steep effect.
  5. MY and color please? and you want leatherette not leather right?
  6. Well, you could. The rear side panels will need to come off to get to the belt bolts and in the end the belt (slotted) trim will still be there. I'd say 30 minutes to an hour if you have the right tools (and don't drop the front screw into the side of the chassis). ;)
  7. Same way, mine just slides off towards the bottom.
  8. 1. Yes, if it corrects itself within a period of time. 2. We would need the fault codes in order further diagnose the error and potential problem area.
  9. Yes, you can measure the resistance they should all be the same. One (or more) that much higher or lower indicates a problem.
  10. Anyone that has a cap with the part number ending in 00 should the cap regardless. It WILL leak.
  11. If you car is not lowered it should only take a few minutes. Also if the plastic screws are sheared off then you might have to poke and pry them out. Still I think less than 30 minutes. I think you should buy new fasteners.
  12. 996-555-122-04-ESZ is leatherette not leather.
  13. The GT3 gearbox is different (type G96.90, G96.93, G96.96) from the standard Carrera's (types G96.00, G96.01, G96.30, and G96.31). Also, I think you can replace gear sets in a GT3 gearbox but they don't list all parts in the gearbox.
  14. Dell, I think Porsche only sells the whole door panel - so a part number may not help. Another option would be to find a good upholstery shop to see if they can replace just the one panel.
  15. 1. Potential fault P0740 causes are: - ATF level not OK - check ATF supply - Torque converter clutch worn. - check torque converter - Mechanical damage to pressure regulator 4. - check pressure regulator 4 (hydraulic) - Open circuit, short circuit to ground, short circuit - check electrical triggering to pressure regulator 4 to B+. - Hydraulic control unit - check for sticking valves. 2. Not all pcodes cause a CEL light. If the speedo signal problem is ABS related then you may have an ABS code. Unfortunately Porsche has not shared those codes with many companies so ABS can not be read with scan tools other than a PST2 or PIWIS. Your car can also generate code for Body faults - B code, C drivetrain faults - C codes, and U faults - for undefined (by SAE) faults. Porsche only publishes P codes. Some independent shops have invested in PST2 tools so perhaps one could read your full code faults for you (for a nominal fee). Either way you should try to identify and fix the P040 cause - which could be as simple as low ATF level.
  16. 996 555 592 00 C51 is #27 - Correct. Porsche only sells the whole door panel (from what I see in the parts list). ETD is the leather color code for a Graphite Grey Leather door panel.
  17. No, not according to the parts list. Cup cars have carbon fiber doors, front hood and rear wing.
  18. That part number is for the door handle only (sorry Porsche had bad naming in the parts list). If you want the rest of the door panel it would be (for a MY2000 Cab): 996 555 121 05 ETD Graphite Grey Leather - Door Panel (Left) 996 555 122 05 ETD Graphite Grey Leather - Door Panel (Right)
  19. The part number is for the door panel lining - but it needs a color code to be complete. I'll sent you a PM with instructions.
  20. There are 4 different emergency wheels for 996's depending on year and model. My guess is that some are based on trunk area and some are based on body type (i.ae. C4S vs. coupe). There are no specs in the parts list for wheel size - but then these are not meant to go more than 50 miles. I don't see any reason why one would not work.
  21. The is a complete wheel set. I do not know if it includes tires or not.
  22. For oil changes you don't even need ramps. I use 2 x 10s - three per side. More than enough clearance.
