  1. 1. Yes, if it corrects itself within a period of time. 2. We would need the fault codes in order further diagnose the error and potential problem area.
  2. Yes, you can measure the resistance they should all be the same. One (or more) that much higher or lower indicates a problem.
  3. Anyone that has a cap with the part number ending in 00 should the cap regardless. It WILL leak.
  4. If you car is not lowered it should only take a few minutes. Also if the plastic screws are sheared off then you might have to poke and pry them out. Still I think less than 30 minutes. I think you should buy new fasteners.
  5. 996-555-122-04-ESZ is leatherette not leather.
  6. The GT3 gearbox is different (type G96.90, G96.93, G96.96) from the standard Carrera's (types G96.00, G96.01, G96.30, and G96.31). Also, I think you can replace gear sets in a GT3 gearbox but they don't list all parts in the gearbox.
  7. Dell, I think Porsche only sells the whole door panel - so a part number may not help. Another option would be to find a good upholstery shop to see if they can replace just the one panel.
  8. 1. Potential fault P0740 causes are: - ATF level not OK - check ATF supply - Torque converter clutch worn. - check torque converter - Mechanical damage to pressure regulator 4. - check pressure regulator 4 (hydraulic) - Open circuit, short circuit to ground, short circuit - check electrical triggering to pressure regulator 4 to B+. - Hydraulic control unit - check for sticking valves. 2. Not all pcodes cause a CEL light. If the speedo signal problem is ABS related then you may have an ABS code. Unfortunately Porsche has not shared those codes with many companies so ABS can not be read with scan tools other than a PST2 or PIWIS. Your car can also generate code for Body faults - B code, C drivetrain faults - C codes, and U faults - for undefined (by SAE) faults. Porsche only publishes P codes. Some independent shops have invested in PST2 tools so perhaps one could read your full code faults for you (for a nominal fee). Either way you should try to identify and fix the P040 cause - which could be as simple as low ATF level.
  9. 996 555 592 00 C51 is #27 - Correct. Porsche only sells the whole door panel (from what I see in the parts list). ETD is the leather color code for a Graphite Grey Leather door panel.
  10. No, not according to the parts list. Cup cars have carbon fiber doors, front hood and rear wing.
  11. That part number is for the door handle only (sorry Porsche had bad naming in the parts list). If you want the rest of the door panel it would be (for a MY2000 Cab): 996 555 121 05 ETD Graphite Grey Leather - Door Panel (Left) 996 555 122 05 ETD Graphite Grey Leather - Door Panel (Right)
  12. The part number is for the door panel lining - but it needs a color code to be complete. I'll sent you a PM with instructions.
  13. There are 4 different emergency wheels for 996's depending on year and model. My guess is that some are based on trunk area and some are based on body type (i.ae. C4S vs. coupe). There are no specs in the parts list for wheel size - but then these are not meant to go more than 50 miles. I don't see any reason why one would not work.
  14. The is a complete wheel set. I do not know if it includes tires or not.
  15. For oil changes you don't even need ramps. I use 2 x 10s - three per side. More than enough clearance.
  16. TWC= Three Way Catalytic Converter. These codes means that what is going on is damaging to the catalytic converter (flashing CEL) and the car should not be driven. Potential causes for this are: - wrong, fouled or faulty spark plugs - bad spark plug connectors - loose or broken spark coils - valve lifters (if chattering) - camshaft control (on that bank) - Variocam not switching over properly A scan tool should be connected looking for other codes. As well you should check to see if the adaptation values in area 1 differ in bank 1 and bank 2 (e.g. TRA=0.02/TRA2=0.27), the adaptation values for area 2 are generally normal.
  17. Coolant hose. The parts list says to use a newer 996 106 233 55 instead (if available).
  18. 955 362 138 20 9A1 19" Design Wheel 9J x 19 H2 offset 60 mm
  19. This one is a Porsche PSE.
  20. Porsche only sells the whole lens assembly. 996 632 151 00 Lens (for MY99) - retail $14.60
  21. Does it "spring" open? If not then the spring may be backwards or not on the right points. Shouldn't make any noise either.
