  1. P0130 - possible faults: Crack in ceramic material Reference air polluted Short circuit in signal wire to sensor ground P0130 - possible causes: Oxygen sensor Wiring harness DME control module (intercore short circuit). P1124 and P1126 mean that the whole engine is running lean and the DME can not compensate for it making the mixture more rich. In most cases this is caused by: Intake air system leaking Fuel pressure too low Volume supply of fuel pump too low Fuel injectors fouled (not likely since this would mean all are fouled) I would solve the P0130 then reset the codes and see if the others still occur.
  2. Yes, phone prep. Brown - ground Yellow/Black - telephone mute Green/Black - switched 12 volts Red/Green - unswitched 12 volts
  3. We have added a new Products and Services Reviews section to the site. You can get there by click on the Reviews link in the upper right corner of any page or by click on the forum link Reviews. The Reviews section is be part of the site so if you are logged into the forums you will be logged into the Reviews section. All members (Contributing and regular Members) can submit products (if they are not already in the database) and then review/comment on any of the products. You can do searches by keyword(s) and/or category, username, or date; see latest reviews by last day, last 7 days, last 14 days or all reviews. Each product shows: Recommended By (percentage), Average Price (currently only in USD), Average Rating (by all reviewers). We've tried to add common categories so, if you don't see one you think should be there please let me know. A couple other nice features are a Watch list which allows you to keep a linked list of products you want to keep an eye on. You can also choose to be notified by email if a product is updated or a has a new review. Once again, thank you to all the Contributing Members that make additions like this possible! Reviews
  4. All Contributing Members have access to all the TSBs. As well they can view and post in the Contributors Only Forum. They can now can send attachments with PMs (Personal Messages) and image storage limits are raised. RennTech.org email addresses are available to Contributing Members and, they can have their own personal RennTech.org Blog.
  5. The red rear brake calipers for the Boxster are 996 352 421 13. They are the exact same size as the 996 standard brakes - just red. Boxster S front rotors are 318 mm, rears are 299 mm - same as the 996. I have no idea what you mean by width.
  6. I already answered this here. The MY02 C4S does use a different kit (according to the Porsche parts list) than the MY03 and later cars.
  7. I think this have been covered here many times... Try using the search function and search all forums for ipod.
  8. 996.351.425.xx and 996.351.426.xx are front calipers (left and right) for a 996. The xx would designate whether the car is a C2 (2WD) or C4 (4WD). 996.352.425.xx and 996.352.425.xx are rear calipers (left and right) for a 996. The xx would designate whether the car is a C2 (2WD) or C4 (4WD). Factory front pads are: 996 352 949 02 Factory rear pads are: 996 352 939 03 The Boxster S uses the same front calipers as a 996 except the are red.
  9. It is more likely a "Workshop Service Action" which is a voluntary service action as opposed to a government "recall". I see if I can get a copy of the workshop service action bulletin.
  10. Are you talking about the "Porsche Child Restraint System". If so what part number did you purchase.
  11. And more Porsche, Penske Motorsports To Run Together With New Prototype In American Le Mans Series
  12. I removed mine (both screens) 3 years ago. I disconnected the battery at the time and had the DME relearn the air flow. Zero problems.
  13. 000-044-500-28 is a 10 mm RoW sport kit for a (coupe, 4WD, 6 speed). I think the MY02 C4S must be different. This the MY03 C4S page from the (Feb 2005) RoW tequipment parts list:
  14. The factory side skirts used in the narrow body Aerokits were all the same from MY01 on. I think the parts kits only come with the complete aerokit package - so you will need to order them too. 996 559 983 04 Left sill cover (in primer w/double stick tape) 996 559 984 04 Right sill cover (in primer w/double stick tape) Two parts kits 000 044 801 65 Various bolts and nuts
  15. Wow! Did the flywheel bolts perhaps come loose and the timing ring hit something (as it wobbled)?
  16. 1. No this is an RoW 20 mm lowering kit. All parts for the X73 package are marked X73 in the parts list. 2. There is a left and right front strut in that kit.
  17. It is hard to say what the differences are in the later ones. Could be just a vendor change. No one has ever proven any performance differences with any of them even over stock.
  18. :lol: ... no need to Google it it's right here
  19. The difference (I believe) is between the standard power steering and the optional (Option 1N3) Variable Assist Power Steering - Servotronic speed sensitive power steering. This shows as available on all Cayenne models.
  20. Item 27: 996 701 801 00 Left spacer retail $0.89 996 701 802 00 Right spacer retail $0.89
  21. Tell us which items numbers you need (I assumed a US car but you didn't say).
  22. I am not sure what the "SM" code (next to your paint code) stands for on your code tag. For instance my car has a Boxster Red interior and the code on my tag is "MA". Perhaps someone else here knows?
  23. :oops: forgot the X45 X45 - Instrument dials in interior color Sorry, I meant a pic of the interior. Is there more than one color used or special order trim? A pic would really help
  24. XRB - 18" Sport Classic 2 Wheels 236 - 18" Tires 689 - Prep for CD Changer 695 - CD Radio CDR 22 I have no idea what SM refers to. Do you have a pic?
