  1. All TSBs are available to view (here) online to Contributing Members.
  2. Always use the whole TSB number. Porsche reuses the 4 digit number when the topic area is the same. For example there are 3 TSBs that have the 6128 number but they are actually 9/97 6128, 3/04 6128, and 3/99 6128. Glad you got it fixed!
  3. 2 hours labor for a 15 minute job? Oh my... At least it is fixed now :cheers:
  4. Could we have the year, exact model, mileage, US or RoW car please?
  5. Did you read the note in step 3 about lighting up the switch? Did you try that? The only power close is the window switches as the ashtray light only comes on with the headlights.
  6. All 300 series faults are misfires that can damage the catalytic convertor. P0300 is multiple misfires and P0304 would be cylinder 4, P0305 would be cylinder 5 etc. P1316, P1317, P1318, 1319 are also misfire detection emissions relevant. Again these refer to cylinders 4, 5 and 6. P0150 Oxygen Sensor Ahead of Catalytic Converter (Cylinders 4 - 6) - Intercore Short Circuit or Limited Voltage Increase. So the problem you fixed was on the 4,5,6 engine bank side? If it was then you likely got the problems. Now you will need to wait and see if the light comes on again.
  7. You can buy an exchange engine from Porsche for under $7000 and I'm pretty sure they come with a warranty.
  8. I found a second source (AllData) and they say gear oil too. Makes sense to me - I think the service manual is wrong. I will correct the DIY page.
  9. I have never done this on a C4. I quoted you what the service manual says (see below). The service manual could be wrong - the easiest way to tell for sure is to take the fill plug out and stick your finger inside to touch the oil. If it comes out with a red colored very light oil then it is ATF if it comes out with a thicker yellow/brown oil then it is gear oil. Please let us know if the service manual is wrong!
  10. I don't think I would. For the reasons explained above (gearbox and diff in the same casing and hence using the same oil), I'd use a transaxle-specific oil. Almost all major oil manufacturers make them, Mobil 1 calls it PTX, Shell calls it Transaxle, Castrol calls it TAF-X. There is a reason why Porsche (or in fact GETRAG) recommend a specific oil. Obviously you can pour in whatever you want, but if you knowingly discard the manufacturer's advice, then don't complain if your gearbox (and in particular the synchromesh) doesn't last as long as you might have hoped. Also, I wouldn't necessarily go with people's recommendations "ABC is a good oil for Porsche boxes". Very few people understand the specifics of gearboxes, not even car manufacturers themselves (they just buy them in) and certainly not the mechanic at the dealership. But why not just go with the gearbox manufacturer's recommendation and be on the safe side? Cheers, Uwe PS: I know that the old G50-bases boxes used any old 75W-90 API GL5, but the synchro was different and the change intervals were shorter. Mobilube PTX is not sold in th US - except by Porsche dealers at a 5X markup. Mobil's Specs: Mobilube PTX (synthetic) 75W-90 GL-4, GL-5 Mobilube 1 SCH (synthetic) 75W-90 GL-5,PG-1,PG-2
  11. If your car was built before March 25th, 2004, as of the following VINs: 99 84S 62 2452 USA then they can do the TSB and be reimbursed by Porsche. Perhaps you should suggest they read TSB 7/04 9662 Insufficient Range of Remote Control (dated 8-13-04)
  12. Congrats! :thumbup: Follow the manual and you will never be denied any warranty claim.
  13. Start by checking the fuses. Once the air bag light is only a dealer or shop with a PST2 (or PIWIS) tester can turn it off.
  14. I got mine from Wiha Quality Tools for about $8 plus shipping. http://www.wihatools.com/773serie.htm
  15. Torx E12 required for seat bolts:
  16. Well, if you don't want to pay the dealer then I would use the Mobil 1 75W-90 synthetic gear oil. Dealer prices: 000 043 204 20 Mobil PTX - 20 liters (retail $550.32) 999 917 546 00 Shell Transaxle - 1 liter (retail $29.57) Mobil 1 75W-90 synthetic gear oil street prices: 3 quarts - $25
  17. Yes, these decals fit Boxster, Carrera, Turbo, GT2 and GT3. I think the photo was on a Boxster (all the other cars have cross-drilled rotors).
  18. ..or here at the Decal/Racing Number store.
  19. Yes, gear oil for manual transmissions and rear differential. ATF for the front wheel drive.
  20. We have added the procedure for changing the (ATF) oil in the front wheel drive of C4 and C4S. You can find it here.
  21. For street driving and occasional track use I would stay with the Mobil PTX. You won't need 12 quarts you will only need slightly under 3 liters. You will also want to change the gear oil in the front wheel drive on your car (4 liters of ATF). I will try to get a DIY online here in the next couple of days - it's not too hard.
  22. Header to engine: 19 ftlbs. (25 Nm) Header to cat: 22 ftlbs. (30 Nm) Tailpipe clamp: 27 ftlbs. (23 Nm)
  23. Well, the codes give say the sensor 1 is bad (sensor 1 - cylinders 1 to 3) for sure. Will it cure the other fault on the other side? You won't know until you replace the bad sensor and clear the codes. If they come back then you need to find out where the next problem lies. Like most compound problems the only way to fix them is to separate the variables and fix the problems one at a time.
