  1. If you like a product - please feel free to add it and review it in the Reviews section.
  2. A factory slant nose for RoW cars should be option 506 (US cars was 505). See if the original option codes include option 506.
  3. Check your rear sway bar. It is fairly common for a mount to come loose.
  4. Ok, I think it is 900 219 007 02 screw plug M10 x 1 about $2.31 retail.
  5. 1. Yes (that is the correct number for a MY99-01), always use the latest Porsche recommends. 2. No, just be patient. The last one on each side will take as long as aa the others. Try a ball end allen wrench and a short wobbler extension is handy for the plug angle too. 3. They should be okay until you can change the rest. I'll let one of the doctors here answer the last question... ;)
  6. This is kind of hard to find... did it have a sealing ring (washer) on it too?
  7. You can find (and download) a generic PCM2 manual in our manual section here.
  8. I use an bulb type anti freeze tester that shows you the freeze protection (in degrees) on one side and boil over protection on the other. Most good auto parts stores have these.
  9. My coolant is 6 years old next month. It is neither dirty or broken down. I test it at least once a year and it has not lost any of it's cooling properties. Unless you have a leak or somehow dilute the mixture too much with water I see no reason to change it.
  10. On a Carrera this is not an easy task. You must remove all the cars underbody panels and disconnect several hoses to completely drain the coolant. To refill, Porsche highly recommends uses a vacuum pull method. This method of drawing coolant in minimizes the chances of trapping air in the system (a real problem in this design). If you don't use the vacuum method you will have air trapped in the system that could take weeks to bleed out. I've seen the vacuum method done it it works very well so I highly recommend it. Do a search here for coolant type there have been many postings on the Porsche coolant and the OEM company that makes it for Porsche.
  11. Loren, is there a difference between the 996 and 997 sport exhaust muffler? Yes.
  12. The Porsche TSB is 4 pages of how to fix it. It requires new parts and the drivers side parts are different from the passenger side parts. You can view the TSB by becoming a Contributing Member (a minimum $25 donation) or you can take the care to a shop and have them perform the procedure.
  13. PCM 2 was introduced in the MY03 cars - so no, in will not work on a MY01. PCM 1 was optionally installed in MY 1998 to MY 2002 vehicles. PCM 2 was optionally installed in MY 2003 and up vehicles. See the topic here.
  14. An engine vacuum leak will throw a CEL in almost every case. Has anything electrical been added or changed recently? aftermarket radio, amp, phone, etc.?
  15. There is only one belt even on a turbo - worth a check to see if it is slipping. Well, from all the symptoms you describe... if the voltage is too low then the fuel pump will not run right - which will make the motor run rough which will lower the vacuum to the brake booster. Also, when you run the AC both front fender radiator fans go to high speed and stay on until the AC is turned off. What happens if you turn the lights on? Same, better, or worse? If there were an air leak at the motor then I suspect you would have a CEL by now. If you have a scanner it might be worth a look to see if there are any codes. Does your CEL light up when you turn the ignition to on? (or is the bulb burnt out).
  16. I would start by checking all the cars ground points for loose, rust or other corrosion. With all the weird electrical problems it sounds like low voltage to several components. I'll send you a drawing via PM here that shows all the ground points for a RHD 996 - it ought to be close to a TT. The problem could also be a battery that is not holding a charge. How old is your battery? Most only last 4-5 years. Have someone check the specific gravity readings and make sure all the cells are good. Third possibility is the alternator is not putting enough current out to charge the battery and run the electrics. Not unheard of but it would be last choice.
  17. All TSBs are available to view (here) online to Contributing Members.
  18. All TSBs are available to view (here) online to Contributing Members.
  19. Always use the whole TSB number. Porsche reuses the 4 digit number when the topic area is the same. For example there are 3 TSBs that have the 6128 number but they are actually 9/97 6128, 3/04 6128, and 3/99 6128. Glad you got it fixed!
  20. 2 hours labor for a 15 minute job? Oh my... At least it is fixed now :cheers:
  21. Could we have the year, exact model, mileage, US or RoW car please?
  22. Did you read the note in step 3 about lighting up the switch? Did you try that? The only power close is the window switches as the ashtray light only comes on with the headlights.
  23. All 300 series faults are misfires that can damage the catalytic convertor. P0300 is multiple misfires and P0304 would be cylinder 4, P0305 would be cylinder 5 etc. P1316, P1317, P1318, 1319 are also misfire detection emissions relevant. Again these refer to cylinders 4, 5 and 6. P0150 Oxygen Sensor Ahead of Catalytic Converter (Cylinders 4 - 6) - Intercore Short Circuit or Limited Voltage Increase. So the problem you fixed was on the 4,5,6 engine bank side? If it was then you likely got the problems. Now you will need to wait and see if the light comes on again.
  24. You can buy an exchange engine from Porsche for under $7000 and I'm pretty sure they come with a warranty.
  25. I found a second source (AllData) and they say gear oil too. Makes sense to me - I think the service manual is wrong. I will correct the DIY page.
