  1. PM me your VIN and I will look it up on the Porsche database.
  2. Are you using a Porsche specific scanner to check for fault codes?
  3. If you get wheel spin this can sometimes happen. It basically resets itself afterwords.
  4. Try 1094
  5. Fault code 1772 Pressure sensor signal wire Possible cause of fault - Short circuit to B+ in the wiring of pin 84 of the level control module - Short circuit to ground in the wiring of pin 84 of the level control module - Open circuit in the wiring of pin 84 of the level control module - Level control module receives implausible signal from pressure sensor - Pressure sensor faulty - Level control module faulty
  6. Try 4828
  7. Porsche PET parts list - we have a paid subscription.
  8. Item 2 - 996 551 211 00 Front footrest -- US MSRP $16.01 Item 3 - 999 073 062 02 Panel Screw -- US MSRP $0.89 Item 4 - n/a Panel Nut (common consumable part) Item 5 - 996 551 611 00 Cover for footrest -- US MSRP $15.02 Item 6 - 999 919 161 09 Fillister head bolt -- US MSRP $1.00
  9. Try 1287
  10. Which item(s) do you need?
  11. Try 0983
  12. https://www.renntech.org/forums/applications/core/interface/file/attachment.php?id=37501
  13. CDC-3 is the 6 disc cd-changer in the front trunk. Try 3231
  14. Try 1216
  15. Try 8316
  16. Try 5380
  17. Put a Porsche specific code reader on the car (like PIWIS or Durametric) and report the fault code(s) here.
  18. Try 0171
  19. Try 31136
  20. The alarm microswitch for the center oddments tray cover.
  21. Try 4625
  22. Try 6419
  23. I have had good luck with Rejex; Amazon.com WWW.AMAZON.COM
  24. Try 4278
  25. Try 2154
