  1. Yes, that's it! The black rubber cap is the dust protector. Don't forget to put the dust cover back on when you are done.
  2. You can't see it in either picture. It is up high on the transmission - near the top where the transmission meets the engine. You will another 1649 to catch Tool Pants and 3180 to catch me... :lol: :lol: :lol:
  3. You mean X73 (for TT and C4S) right? X73 does not include new swaybars - nor does PSS9. You can add the the GT3 adjustable swaybars to either - although I think you will need custom drop links.
  4. The TSB expalins it all... ;) ;)
  5. I think your dealer needs to read TSB 1/04 9110 PCM2.1 & BOSE Amplifier Spare Parts Requirements (dated 7-05-05). This TSB describes how to upgrade from the old (no longer available PCM 2.1) to the newer design. The listing shows what replaces what and then gives 5 pages of instructions of how to update the software on both the PCM 2.1 and the BOSE amplifier. If that does not work then I think you need to find a different dealer.
  6. 17" wheels will fit any 987 - as long as they meet the factory offset and width specs. Here are the factory 17" wheels for Boxster (987) (not Boxster S (987)): Front: 6.5 J x 17 H2, offset 55 Part No. 987.362.122.005 Rear: 8 J x 17 H2, offset 40 Part No. 987.362.126.00
  7. There does not appear to be a kit to retrofit the ParkAssistent option. Looking at the schematic it does not appear to be too complex. But routing the wires in the car may be the big problem. The ParkAssistent consists of: - a control module which is located under the driver's seat together with a cover plate. - four ultra-sound sensors which are installed in the rear bumper. - an audible signal transmitter which is integrated into the instrument cluster. Electrical connections need to be made between the each of the four sensors, the control unit, reverse signal wire, the instrument cluster, power and ground.
  8. Yes, any dealer can tell by VIN - even over the phone. I think most MY02's had a four year warranty - best hurry.
  9. Porsche is on their 6th tank design - the newest tank (the one you want is 996 106 157 03). If your car has warranty left then it should be replaced under warranty.
  10. Your dealer is wrong - first the 997 engine is the same engine as the 996 - some cars can use a quart every 1500 miles and some do not. For instance my MY99 does not use any oil between changes at all. If your car does not use oil then simply smile at those folks that complain about using a quart every 1500 miles. :D
  11. Step one is to identify where they are coming from. There are solutions for most of the rattles, etc. but they are specific to location.
  12. That connection looks the same as mine. There should be a flare on the plastic piece that keeps the hose on with the clamp. I wouldn't worry about that connection. 01 is the latest cap - besides when the cap leaks you see residue on top of the tank. If you see a leak on the ground near the left rear wheel (and the cap is on tight) then it is likely the familiar coolant tank crack. Many times the crack is on or near the bottom of the tank is very hard to see. I'd keep an eye on it but it sounds like a cracked tank from what you describe - sorry.
  13. Yes, moisture in the fuel can cause gas line freeze. Most good gasoline suppliers add some deicer (methanol) to there fuel shipments in the winter. If that is a concern then buy and use some HEET Gas-Line Antifreeze and Water Remover. It will not hurt anything and it will remove water/moisture from your fuel.
  14. P1117 Oxygen sensor heating after TWC, bank 1 Potential causes: Heating current too high – Heating resistance too low – Short to B+ Heating current too low – Short to ground – Corrosion in connector – Break in wiring Open circuit – Break in wiring – Heating resistance too great Internal resistance of oxygen sensor too high – Open circuit in sensor line – Oxygen sensor How many miles on your car? It is not unusual to lose an O2 sensor after 60,000 miles. Bank 1 on a Carrera would be the drivers side - sensor after the cat. You will need a cat wrench or a 22 mm wrench. Do not get any oil (or any other substance) on the sensor. The sensor should come with high temp anti seize put that on the threads but not on the sensor.
  15. That part number is the only Tequipment US Nav system retrofit kit for both the Carrera (997) and Boxster (987). So if it is the wrong head then it must have come that way from the factory. Do you know the part number of the head unit? and, How do they know it won't work? There are different wave guides (fiber optic cables) for different options but the install TSB only shows one head unit.
  16. Engine, transmission, brakes, and suspension are all different. They share most body parts and chassis.
  17. Well, I usually spray and make sure any deposits are cleaned out. It should move freely when you are done. You do not need to remove the throttle body to clean the solenoid valve - just remove the valve using the precautions I mentioned. Did you open the butterfly to clean the carbon build up behind it? If you can do that well on the car then it might be easier to remove the throttle body. How do you know the MAF is bad? You can disconnect the MAF completely and the car will still run pretty well.
  18. Have a look here for a pic, description and how to clean.
  19. Usually the MAF works or it doesn't. Did you look for carbon buildup in the throttle body and idle valve solenoid? If those are both clean and it still runs the same then a scan tool (that can read) MAF air flow should tell you if the MAF is questionable.
  20. US lights do not get the headlight leveling system. 000 044 900 39 is the part number for Litronics upgrade kit for RoW LHD cars. The TSB is here in the TSB section which is viewable by Contributing Members.
  21. One Tiptronic ground point is located in front of the instrument cluster on the dashboard support frame. The other Tiptronic ground point is located on the rear wall in the rear luggage compartment, between the DME control module and Tiptronic control module. There is also a connector that should be checked for corrosion or loose pins. Plug-in connector X 2/6 (21-pin, blue) is located beneath the convertible top on the right-hand side member (in the vicinity of the lower safety belt attachment).
  22. Gumout is a brand name I use. It is basically lacquer thinner - just keep it off the paint.
  23. 000 044 500 16 is for MY98 to 01 C4, Cab, 6 speed
  24. :oops: I thought you couldn't find it here... :lol: The paint data plate is located in the front of the luggage compartment on the left side wall under the carpet lining.
  25. Use the drop down menu Online Docs Menu then select External Paint Colors from the page menu choose Carrera (996) External Paint Colors.
