  1. Probably. Since it is also an add-on option I suspect it can be removed. You may need a console (leather) piece to replace where the phone was.
  2. Are you having any other electrical anomalies? Does the alarm beep once when you lock the car?
  3. The lamps from a GT3 RS will not fit a mk1 GT3 without changing the front bumper, lamps (and wiring), and both front fenders. Litronics (Xenon) kits are sold here in the states for about $1000 - $1200 new. If you are lucky you might find some on eBay - but I doubt it as they are pretty popular.
  4. There is a TSB that describes the installation - TSBs are available to view online here to Contributing Members.
  5. You are re-connecting the electrical connections to the locking solenoids right?
  6. The PST2 Porsche part number is: 000 721 958 80. You will find a complete list of all part numbers (Porsche and Bosch) near the end (Section 8) of the built-in operation instructions (F1 - Help from the first screen). In the US parts list the PST2 is there -- but it is not on the US price list.
  7. Very interesting... We were told by two different dealers here in the US that PST2 is no longer sold or supported. Do you know if they are still selling PST2 in Europe - and software updates?
  8. You got any information that we can look at about this software? What are the hardware reqs? Thanks, Darren Have a look at this thread.
  9. Yes, MY99 and MY00 share all the same wiring colors.
  10. The PST2 will work "somewhat" for a 997/987 with limited capabilities. To do that, you do need version 24 of the PST2 software. There are several controller functions in the new 997/987 that PST2 does not even see.
  11. Not really, the whole latch has to come out. Re-install requires a realignment of the latch too. If you you have a volt meter you can check the circuit that way.
  12. You will need a PST, PIWIS or a new software product (that I am currently reviewing) from Durametric Diagnostic Software. The code reported (and read by any of these tools) should tell you what caused the airbag light. If your MY99 car has never had the seat belt buckle and connector TSB done then it is likely that it needs to be done now. Chances are one of the troublesome connections on the buckles or the wiring connectors is making poor contact. The TSB replaces the connectors (in both the buckles and wiring harness) with gold contact connectors that fix the problem for good in almost all cases.
  13. Folks - please - back on topic (so I don't have to close this thread)... thanks!
  14. The DME learns certain aspects of driving habits but not PSM. That is, not directly - PSM makes changes based on DME input (as well as ABS, engine speed sensors, rotational (lateral acceleration) sensor, steering angle sensor and brake pressure sensor). To my knowledge you can not change any map in the PSM system.
  15. If the switch is not off, and the bulb is good then chances are it is the microswitch on the front hood latch. If it is the microswitch I would think you would also get an alarm beep when you set the alarm (signifying a zone is open).
  16. You should be able to get the emergency cable through the wheel housing - without any damage. Simply remove the plastic rivets and the one 10 mm nut that hold the wheelwell liner in and grab the cable and pull to release the front trunk. Worst case is that you break a plastic rivet or two (about $0.39 each).
  17. There is certainly a chance that the ignition switch is bad - a fairly common problem. Look in the 996 Carrera DIY - Common Fixes for a DIY on ignition switch replacement. I would just make sure that you have the right key - which a dealer should be able to do.
  18. http://www.renntech.org/forums/index.php?s...indpost&p=21380
  19. The Retail Price Search feature (for our Contributing Members) has been updated to reflect January 2006 pricing and 202,016 parts.
  20. Did the shop check your steering angle sensor actual value. It must be checked after a suspension alignment even where no changes were made to the wheel alignment values. All C4's and cars with PSM REQUIRE this according to Porsche. From the service manual: You can also check the brake fluid level and the battery condition - both have been know to cause this. If not one of those, you will need to find a shop or dealer that has a PST2 or PIWIS tester to read the codes. The code(s) should point to the problem.
  21. Both the drivers keys (usually two) for a MY99 car have one button and should both lock and unlock the car as well as the ignition. The valet key is a lighter gray and does not have any buttons - it will work on the drivers door (key lock) and the ignition. I suggest you write down your VIN and visit your local dealer - with proof of ownership. They can tell you if you have the right key cut (for the metal part of the key). If the programming is wrong then you will need to buy a new key and have it programmed to the car - the car will need to be present for this procedure. Perhaps they can cut a metal key to allow you to drive the car down for programming. Once a key is programmed it can not be changed.
