  1. The OBDII manual says: "- EVAP canister purge valve open - Pressure sensor faulty" The valve is back on the engine - the pressure sensor is back near the engine too.
  2. Thanks for the feedback. I'm glad we know what will fix that fault - now.
  3. There are Owner's Manual here online to download -- Click Here
  4. Did you look in your Owner's Manual? ;)
  5. That is where it is. You may need a strong light to see the stamping. Depending on the state/country you live in it may be on your vehicle registration too.
  6. Since Porsche specifies exact tire sizes in the owners manuals and in a yearly published TSB I doubt it is written down anywhere. The ABS system is reading the speed sensors on each wheel hub so if the system senses enough difference it could trigger too early or too late or even shut down ABS with an error. I would call the tech guys at Tire Rack or Wheel Enhancement and see what they say about a 2.7% difference.
  7. No TT tailpipes won't fit a Carrera (C2, C4, or C4S) . Different engines, different exhaust system. The C4S exhaust exits the muffler at the top and bends down (almost 90 degrees) to the bumper opening. The TT exhaust comes straight out the of the muffler (no bends at all).
  8. Maybe it's just a bad radio?
  9. Take a look at my posting. The dealer used the same "bad gas" excuse on me as "thelion" mentioned in his January 9 reply to you. A number of people are having this problem and since no service codes are triggered Porsche says there is nothing wrong with the car. Clearly a car that sputters has something wrong with it. See my post here.
  10. Well, at this point I would say it is either the MAF or the DME program...
  11. 996.343.069.03 Left stabilizer mounting -- retail $41.38 (as of Jan 2006) 996.343.070.03 Right stabilizer mounting -- retail $41.38 (as of Jan 2006) 999.084.445.09 Hex Nut (bar side) -- retail $1.21 (as of Jan 2006) 999.084.643.09 Hex Nut (chassis side) -- retail $1.19 (as of Jan 2006)
  12. I just received the Durametric software and cable. I've barely had time to look at it yet. At this time it looks like -- code identification and reset for DME, Air Bag, ABS, Alarm, AC, and Seat Memory -- no PST2/PIWIS functions beyond that. I know they plan on more and I will try to get details as I progress in my review of the product. I plan to try it on 986 and 996 with DME 5.2.2, DME 7.2, and DME 7.8. The latest US version of software for the PST2 is version 24 and it does include CGT but not 987 or 997. Stay tuned as we have heard that Europe has version 27.
  13. Your car is a MY99 C4? Hmm... If that is what you car is it should not have a P1123. What is your MY and model? What did you use to get the code? P1123 - Oxygen Sensing Adaptation Area 1 (Cylinders 1 - 3) - Lean Threshold Which means that side is running too RICH not too lean. "Lean threshold" means the DME can not lean the mixture enough.
  14. Well there is trunk light on the left side or the battery right in the center or the CD changer (if you have one). Pick your location for the GPS logger.
  15. I asked around with some folks here (shop foreman and independents) and they say that the NW US has had a lot of contaminated gas for several months now. Here is a suggestion... Buy some Shell premium gas then add a can of HEET Gas-Line Antifreeze and Water Remover. The HEET will remove most if not all of water in the gas tank. You should be able to find HEET at Autozone, Pep Boys, Kmart, etc., etc. What have you got to lose?
  16. Hmm... intermittent wipers were standard on US cars (this is a US car right?). All of the service manual docs give the intermittent relay location as position 16 on the relay support 1 (the one in the lower left footwell). On my car it is blue and taller than most of the other relays. The part number is on the side.
  17. Glad you got it taken care of.
  18. The springs are not different betwen a US and RoW Cayman with PASM.
  19. No problems... IMHO likely just profit takers. The price will only go up as they get older.
  20. Yeah, you are right I forgot about the intake temp code - normal with the MAF disconnected. Did you get the right MAF sensor? Should be a 996.606.123.00 (can't find the Bosch number right now...)
  21. Sounds like not enough air - DME 5.2.2 right? Did you use the C2 throttle body or the C4 eGas throttle body? If you clear the codes and disconnect the MAF the car should run mostly fine and you will get a MAF code (P0101 I think). Then see if you still get other codes.
  22. The old intermittent relay should be part number 996.615.103.00. It may not be be in position 16 depending on your cars options. There is only one relay with that part number - so if you can find it replace it with the rain sensor relay.
  23. Replace your car? I've yet to see a problem that can't be corrected. Tell us more about the history. 6 Speed or Tip? Any mods to the car? Has it been doing this since day one? How many attempts has the dealer made? Did they keep the car and drive it for a few days? What have they replaced? Did their shop PIWIS tester show any codes?
